Camera not switching on
Sounds like the battery has failed. if you can, then if you can try and borrow a working battery from someone else with the same camera, and try your battery on their camera just to confirm this is the problem.
If you can't, then just try a new battery - please post again if you are having trouble finding one.
Other possibility is that there is a fault with the charger - again if you can borrow one, you can soon see of this is the problem. Most camera repair shops will have a selection of chargers they can use, so you should be able to check this quite easily.
Hope this helps :)
