Washing Machines Logo
Posted on Oct 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My kenmore 80 series washer ... the tub has stopped spinning although it still sounds as if something is spinning inside the tub isnt moving....does this mean it needs a coupling?
Anonymous
Level 2:
  • Expert 76 Answers
  • Posted on Oct 26, 2009
Anonymous
Expert
Level 2:
Answers
76
Questions
0
Helped
16704
Points
199
1helpful
2answers
Kenmore series 80 washer do not drain enough
It's normal to hear some water in tub, it isn't normal for the rubber wheel to be hard to turn, you need to replace the pump, they are much cheaper on ebay
If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_2094e122cc46f24c
1helpful
I have a Kenmore Series 80 washer and the tub
i would check the motor coupler
it sits behind the motor before the transmission
this model
thre piece part that drives the transmission
6helpful
My Kenmore 80 series. did not spin
most common problem is either the lid switch (made no sound) or the drive coupler(sounds like its working but no spin) also check for anything holding tub(nail trough basket jamming tub etc.)
Kenmore 80 Series washer wont spin or drain at end of cycle
POST ME THE MODEL NUMBER. AND ALWAYS POST MODEL NUMBERS WHEN NEEDING ASSISTANCE PLEASE:)))
GOES TO SPIN CYCLE THEN STOPS SUDDENLY AND REFILLS WATER IN TUB
Are you sure you don't have a second rinse button that is selected.
Washer over flows
Dear Cbelton
please inspect the following
  • Inspect the water supply connections
  • Inspect the drain hose
  • Inspect the water pump
  • Inspect outer tub for cracks or corrosion
  • Inspect the tub seal
  • Inspect the tub bearing
  • please rate this solution.Thank You..
    Broken Washer
    it could be the direct drive coupling that connects the motor to the transmission. fill it up with water and see if it will agitate, if it will NOT agitate then it is a good chance that this is the problem. 0404472.jpg
    worse case scenario is the transmission is bad, but this is unlikely.
    Pounding noise after wash and final spin
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
    if this helps please give a fix ya vote
  • 1helpful
    Kenmore 80 series washer stopped during unbalanced spin cycle
    lid switch is broke lever probley broke off or screw holes broke out due to off balance load forcing tub over against switch lever
    You should still be able to drain the water by selecting a spin cycle and closing the lid, unless the lid switch isnt working
    Alexander
    vince
