eMachines W3507  PC Desktop Logo
Posted on Oct 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I ran the recovery disk and then there was no sound, it says there is no audio device, no mixers
Anonymous
Level 2:
Scholar:
  • Expert 66 Answers
  • Posted on Oct 20, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
66
Questions
9
Helped
59150
Points
204
I found two drivers one for Realtek ( vista )one for sigmatel( xp) on the emachines support website. There might also be some others there that you need. Hope this helps and good luck. If I helped please rate me. Thanks.-jmattes http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=W%20Series&model=W3507
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 226 Answers
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
226
Questions
0
Helped
40690
Points
592
Update the drivers to the correct card .
1 Related Answer
kenneth njonjo
  • 1575 Answers
  • Posted on Nov 14, 2011
SOURCE: no audio device after recovery disc
Hi John,
You may need to re-install the audio drivers again.Though you haven't included your machine's model and Operating System,try this site for driver downloads.
Make sure you select the driver that corresponds with your operating system.
Hope this helps.Thanks!
Bios emachine
First check is your volume mixer if you notice that your audio device is properly working. Simply right click your audio shown beside your time and date and select Open Volume Mixer make it sure that no one is mute. If it is working properly, second is go to control panel and select RECOVERY and open system restore, choose exact date that your audio device working properly. If not simply uninstall and install the driver. All of them it doesn't work just buy usb audio device like this https://www.google.com.ph/search?q=usb+audio+device&client=firefox-a&hs=U7k&rls=org.mozilla:en-US:official&source=lnms&tbm=isch&sa=X&ei=_MDMUqTZCc7PiAfyt4GYDQ&ved=0CAkQ_AUoAQ&biw=1024&bih=718#facrc=_&imgdii=_&imgrc=wfRzEF_R6kAGdM%3A%3B1vCA49U-0gpQJM%3Bhttp%253A%252F%252Fwww.techfuels.com%252Fattachment.php%253Fattachmentid%253D18198%2526d%253D1271760841%3Bhttp%253A%252F%252Fwww.techfuels.com%252Fthreads%252F35253-USB-2-0-3D-7-1-Channel-Audio-Sound-Card-Adapter%3B479%3B369.
No audio device after recovery disc
Hi John,
My hp pavillion a6703w had sound but all of a sudden now sound! I tried everything to fix. Device manager says it is working, but when I go to the speaker picture on the screen it says no audio device is...
take the disk your computer came with one might say recovery disk or drivers disk depending on what you have. and install your audio driver, you might of deleted it by accident, it happens. Please vote for me helping out
1helpful
3answers
My hp mini 110-1000 has no mixer device
A mini note book is a very restricted device - with plain standard audio hardware - go to HP.com - select software and drivers - put in your product number then select your OS - down load the audio driver package.
I am not getting any sound from desktop speakers..i have sony driver installed
Onboard audio is disabled in the BIOS
The BIOS Setup program is accessed by pressing the <F2> key after the Power-On Self-Test (POST) memory test begins and before the operating system boot begins. Go to the Advanced > Peripheral Configuration menu to make sure onboard audio is enabled.
Audio settings in the sound mixer are incorrect
Check your audio mixer software to ensure audio is not muted or the volume level is not turned too low.
The speakers or headphones may be connected to the wrong jacks
Make sure you connect all speakers to the correct jacks. If you connect them to line-in or microphone jacks, they won't work.
Audio drivers are not properly installed
Check Device Manager under the Sound, video and game controllers section for any errors associated with the audio driver. Reinstall the audio driver if necessary.
Audio to back panel is muted if front panel is connected
Check your audio mixer software for a setting that mutes back panel audio if you have plugged headphones into a front panel audio solution. Uncheck this setting to allow audio to both the back and front.
Sound Playback is set to wrong device
In Control Panel > Sounds and Audio Devices, go to the Audio tab. Check the default device for sound playback; there may be multiple selections. Select the desired device, either rear panel or front panel.
My toshiba laptop will not for some reason play sound. i have checked to see its not muted but it still doesnt work. any help?
Go to control panel > sounds and audio devices and have a look in there or click on the advanced button for the audio mixer. in the mixer, go to options > properties and select all the devices, close that and then turn up the volume on the mixer.
Downloading drivers
no sound mixer drive . HP pavilion 2000 using conexant amd audio sound drive
Sound
reinstall your device drivers for your sound device, if it is a build in sound device for windows, just run your windows etup disk and on the second screen, chooset the option repair.
Top eMachines Computers & Internet Experts
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
