Troubleshooting & Support
Hot Topics:
Problems & Solutions
my garmin wont keep up
Correct. Like all satnavs it needs a fairly clear and unimpeded view of the sky in order to connect with the satellites. The signals from...
My etrex worked properly up
Ensure that you have fresh batteries and a clear view of the sky. Turn the Legend on, Click the top right hand button until you see the...
I have a Garmin etrex
You need to make sure your GPS unit and Google maps are using the same map datum. In your user manual:...
I have a Garmin etrex legend, and when I enter the
Go to Main Menu > Setup > Units > Position Format > change to hddd.ddddd format. This is the decimal format which is widely...
Can't view downloaded sections from Garmin...
In Map Setup page, scroll over to blue 'ball' icon (second from right), press lower left button on side of GPS unit, use Thumb...
lines accross the screen
had the same problem, and was told it is a bad connection to the screen. To test, squeeze the sides together.
Consistent error entering garmin etrex coordinate...
Consistent errors are usually projection or datum related. If you are taking coordinates collected in one projection and displaying them in...
screen goes blank when unit is used too long or...
I had the same problem - has been acting up since new but is off warranty. I took it apart and found the oscillator crystal was hotglued...
Unable to locate satellites? Not willing to
Hello there: You can try to press it untill it connects but if it cant find a signal you may have to move to a different location for...
Can't seem to delete my wayward marks.
Delete your waypoints? Find page > Waypoints Scroll down to the waypoint you want to delete Press ENTER and the waypoint details will...
Garmin eTrex Legend using serial connection to PC.
Re-installed the USB-to-serial driver, the DNRGarmin software, and the Garmin Communicator to resolve the problem.
how to get a replacement lcd cover/glass
Hi, I have a Etrex Legend (same size as yours) that no longer works - It has a good lcd cover. email me at rsrogers at screaming dot net for...
Garmin eTrex Legend
Do the following: 1 - Make sure you have fresh batteries in the unit and turn the unit on. 2 - Check the GPS date and Time. On the Main Menu...
I have the garmin extrex legend and need to
you can buy a USB to serial adaptor at almost any computer store. it will install and show up as a com port, you can then update that way. i...
when i turn it on GPS for the first time this year
place the unit outside and let it sync up to the satellites. It should automatically get the time and date.
Unsolved Problems
Loose bottom cover on Garmin eTrex Vista
How do I glue it back into place?
When I push in on power up button it comes on...
It will not power up. Only momentarily.
download Garmin eTrex Legend GPS Receiver software...
software for reinstalling setelites
geocache locations
When I write a location from geocaching website, the location does not appear on my GPS
joystick won't work
worked great for many years, and then last weekend, the joystick will only work in one direction. boo! Help!
garmin locks up
Frequently, my unit freezes up and I have to cycle through screens to have it strt tracing again.
Upload a manual for Garmin eTrex Legend GPS Receiver
Specifications
TopKey Features
Full Product Name:Garmin eTrex Legend GPS Receiver
Form Factor:Handheld
Designation:Outdoor
Map capabilities:Internal, Download maps
User interface:Thumb Stick
Receiver type:Parallel-Channel (12)
Enhanced accuracy:WAAS enabled
Display
Display Type:LCD Display
Display Size:1.1 in. x 2.1 in.
Technical Features
Special Features:Waypoint Icons
Trip calculator:Maximum speed, Current speed, Trip Timers, Time of sunrise/sunset, Track Log
Included Software/Maps:Marine Cartography, City Navigation Maps, North America Maps, Europe Maps, Australia Maps, South Africa Maps, South America Maps, Middle East Maps, Asia Maps
Grids:Lat/Lon, MGRS, UTM, Loran TD position format, Maidenhead
Other Features
Built in Memory:8 MB
PC Interface:Serial RS-232, NMEA-0183
Antenna:Built-in
Enviromental protection:IPX7 Waterproof Standard
GPS System
Update rate:1 per second, continuous
Waypoints:1000
Accuisition time - cold:45 sec
Accuisition time - warm:15 sec
Differential standards:DGPS Ready
Max. Horizontal accuracy:< 49 feet
Enhanced position accurancy:< 10 feet
Number of routes:20
Battery
Battery Life:Up to 18 Hours
Battery Type and Quantity:2 x AA Batteries
Warranty
Warranty:1 Year
Dimensions
Depth:1.2 in.
Height:4.4 in.
Width:2 in.
Weight:33 lb.
What's your problem?
Fix-O-Meter
54,636
54,636 people have viewed this product
- 380 people asked about this product.
- 160 people found solutions for this product.
- 8 people have added this product.
Garmin Nuvi...
TOMTOM turn off...
Motonav TN20...
