KitchenAid 525 Watts KP2671 Professional 6 Series Stand Mixer
Problem for KitchenAid 525 Watts KP2671 Professional 6 Series Stand...
Planetary fell out while mixing bread dough on
By glenntheham on Oct 20, 2009
Planetary fell out while mixing bread dough on KP2671XER. How do you re-install planetary? Is this just a friction fit? Cannot find any screws or pins.
Comments:
Oct 20, 2009
- The parts list does not really help to show how the planetary is installed. Again, it does not show what holds it in place. Please elaborate.
Oct 20, 2009
- Yes, the whole planetary assembly fell out. I do not know why it fell out. I simply want to know if just slipping it back in was the correct thing to do, or if there is something else that needs to be done. Is there a service manual available for this mixer?
Thanks
Oct 20, 2009
- Are we talking about the right mixer? The KP2671 does not have a drain plug, and I can't see where it can hold oil because of the planetary assembly design.
Oct 20, 2009
- Hi,
Sorry to be so persistent, but the manual from mendingshed is for another mixer, and the other link is a parts list, which I already have. Is there a service manual for KP2671? I'm starting to think that there is not one, since I did my own searches.
I am starting to get the feeling that the planetary assembly falls out after a while, and it just has to be replaced, unless it happens too frequently, but I thought looking at a service manual would verify this.
Thanks
Solution #1
posted on Oct 20, 2009
Somewhat Helpful)
njvinod
Rank: Wiz
Rating: 85%, 437 votes
Here is my opinion:
It may be as simple to install the planetary, attacht the hub and tighten the bolds,
You may also have bad bearings in the shaft portion of the planetary ( the shaft your attachments go onto) allowing the shaft to "wobble" a little bit causing a slight misalignment as the smaller gear goes around while mixing causing slipping of the planetary..
Here is the link containing the brakdown parts of your device, just refer the brakdown of the planteray before you install.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208204525.pdf
Please leave me comment,if you need further assitance
RNj VINODKUMAR
Solution #2
Somewhat Helpful)
digritz
Rank: Guru
Rating: 93%, 192 votes
The planetary gear is part of an assembly that includes the washer, fiber washer, pinion gear, retainer clip, agitator shaft and the retaining pin. I am assuming that it was the whole planetary gear assembly that fell out. Since I'm not sure exactly what caused this to happen I am unable to give you a solution to prevent this again unless you can provide more details on anything else that may have came out. I can provide you with a diagram for your mixer.
If not please let me know and add anything more specific about this.
I hope this helps.
Comments:
Oct 21, 2009
- Sorry I did not respond sooner however this is locked by another expert. Since I started this and I am unsure as to whether you have a solution I will try and answer your question.
First I only included the diagram to provide a common reference and aid in assisting you. It's sometimes difficult to convey an accurate explanation with out this. I have also included a second exploded parts diagram. Although this is not a Kitchen Aid diagram they are not the original manufactures of it, Whirlpool is. So this should be the same as your model with only cosmetic differences. Plus this diagram is a much more detailed image.
As I originally stated the planetary gear is part of an assembly and I was unsure as to how much of it came out. After reviewing your latest comments I see that it's the entire assembly.
To remove the planetary gear assembly you need to remove both the dowel pin (part #9), and the retaining clip (part #7). The dowel pin is used to lock both gears #10 an #8 in place. The retaining clip is used to hold the primary shaft in place.
In the sub assemble (lower right hand corner) there is also a dowel pin (part #9), and a retaining clip (part #30) that locks the planetary gear in place on the shaft and holds the shaft up in place. Again these would both have to be removed for it to come out.
Looking through the other comments I noticed a reference to an oil drain. The transmission does require grease but not oil.
I realize that there may still be a misunderstanding regarding exactly what you are referring to however please use the second diagram and label all the parts that came out if there are not part of the assembly I pointed out. Also if this is not your model please let me know that too and I'll try my best to help. Thank you.
Solution #3
Not Rated)
charlymonty
Rank: Wiz
Rating: 82%, 273 votes
the oil in the planettery system got over so it got dryed out and fell down.may be its craxcked and needs replacement.its actually fitted with internal gears.just check out winding it in reverse position.if not possible then it needs to be replaced order the required part from kitchen aid service center.as this part is not available outside.
LUBRICATION
Planetary
The planetary oil should be checked periodically. To check, DISCONNECT ELECTRICAL
POWER SUPPLY and remove the Drip Cup-Splash Guard. Oil should be even with the
bottom of the fill plug hole. If it is not, slowly add the recommended planetary lubricant
until it is. Replace the fill plug and the Drip Cup- Splash Guard.
A Drain Plug is located on the bottom of the planetary. Should draining become
necessary, remove the Drip Cup- Splash Guard and place a suitable catch pan under the
draining plug. Remove the drain plug, allow oil to completely drain, and replace the
drain plug. Remove the fill plug and pour in six fluid ounces of the recommended
planetary lubricant. Replace the Fill Plug and the Drip Cup-Splash Guard. Contact
Planetary Seal
Occasionally, the planetary seal may become dry and begin to squeak. To correct this,
work a little lubrication under the lip of the seal.
Transmission
The transmission oil should be even with the line on the Oil Level Gauge when the
motor is NOT running. If the oil falls below this line, DISCONNECT ELECTRICAL POWER
SUPPLY and remove the Top Cover, which is secured by two screws. Remove the
Transmission Fill Plug and add a small amount of the recommended transmission oil
until it returns to the proper level.
DO NOT overfill the transmission as leakage may result.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Comments:
Oct 20, 2009
- ok the drain plug is in high density kitched aid mixer appliances.in yours its just the normal planetary assembly.it gets worn out and fells out. to get new planetary assembly you can get it from here.click this link directly. http://www.marbeck.com/action.cfm?action=viewcart&thispage=mixers_kitchenaid_parts.html&CFID=13513113&CFTOKEN=86740580 --------- click this link directly and check out how your planetery looks http://www.mendingshed.com/kamisc.html ---------- checkout and keep updated.thanks.
Oct 20, 2009
- click this link directly for seeing the parts fitting in service manual.it will help.http://www.smallappliance.com/images/SmallAppliance/English/products/standard/KP2671.pdf ------------ thanks.
Oct 20, 2009
- i provided the link for your model only.please check it click this link directly for seeing the parts fitting in service manual.it will help.http://www.smallappliance.com/images/SmallAppliance/English/products/standard/KP2671.pdf ------------ thanks.
Popular Solutions for KitchenAid 525 Watts KP2671
Questions and Unsolved Problems for KitchenAid 525 Watts KP2671
Do you recommend KitchenAid 525 Watts KP2671 Professional 6 Series Stand Mixer?
Answer
Answer
beater is scraping parts pof bowl. have turned adjustment screw all the way
Answer
The crank that lifts the bowl up - down is very hard to turn. What should be done?
Answer
when mixing my mixer makes a loud squealing noise, then stops making noise, and then starts again
Answer
Mixing beaters do not touch bottom of the bowl - have adjusted scre. Kitchen aid professional mixer
Answer
when the pro 600 is mixing it starts to make a clicking noise and sometimes takes a while to start?... (More)
Describe your Mixers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Mixer Experts
Top Small Appliance Repairmen
in Newbury, OH
(316) 283-4211
(316) 283-8664
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
