Question about Hobart N50 Stand Mixer
Hobart N-50 Mixer beater attachment spins but has no resistance
This mixer turns on fine and the beater attachment spins but will not spin or mix when dough etc... are placed inside the bowl. Is this a transmission problem? Or a shaft bearing? Can someone please help me diagnose the problem. Is this an easy fix?
Posted by b_badinger on
Gearheadman
    New Friend:
    Problem Solver:
  • 4 Answers
Sounds like the shear pin on the planetary shaft has sheared off. Has the mixer been subjected to a heavy load. Remove the planetary and see if the shear pin is intact otherwise you may have to open up the transmission.
Ron
Posted on Jun 10, 2009
60 qt Hobart mixer H600T makes buzzing noise and won't spin. The hook seems blocked, can't spin it manually. Opened the top part and everything seems fine. What can it be and how to fix it? Thank you
call in an electrician as it may be the start/run capacitor for the motor ( indicated by motor humming but not running)
the gearing will make it very difficult to turn the blades by hand as the motor will be spinning at either 1400 rpms or 2400 rpms down to around 50 rpms for the blades
Jun 30, 2016 | Hobart Food Mixers
The beaters are getting stuck .
If it does this while mixing dough, for example, your mixture or portions may be too much for the mixer to handle.
If it does this with no materials in the mixing bowl- then it sounds like one or both beaters may be out of alignment; a damaged or worn center shaft pin; a worn center pinion gear, a damaged or worn worm gear...etc.
Mar 13, 2015 | Food Mixers
How much oil does my H 600 Mixer hold ( Hobart in the Transmission
1 gallon of 90w Gear Oil -- can be purchased from AUTOZONE! Make sure when you have completely drained from the large drain screw from under the mixer toward the back of where the attachments go on but not part of the part that spins around known as the Beater shaft! Once you have drained out all of the oil -- from the top where the front screw attaches the head or cap of the mixer -- add the oil there and make sure you are watching the sight glass to see when it is at the HALF way mark in other words when the oil level (TIP: Use a bright led flashlight to shine directly at this sight glass to view level) reaches to the midway mark of the oval sight glass, THEN STOP! It is full! Carefully start mixer on 1st gear and then 2nd so on and so forth to make sure everything is getting relubricated correctly and slowly -- don't just go setting it on 3rd or 4th speeds as you want to baby the mixer when you just put in new gear oil
Hope that helps!
Jun 12, 2014 | Hobart H600 Stand Mixer
Dc-sm168
Hello, Go here for beaters for your mixer: Hobart Mixer Parts Hobart Mixer A200
Jun 02, 2014 | Hobart A200 Stand Mixer
Beater is stuck
I had this happen on my Kitchen Aid mixer. There is probably a build up of dough/cake mix etc inside the hole where the beater fits into. Fill a mixing bowl or a jug deep enough to fit over beater with very hot or boiling water. Immerse the stuck beater in the water up to where it connects in to the mixer and hold for about minute. Once the hot water has melted the build up you should be able to remove the beater. Hopefully this may work on your brand of mixer.
Apr 14, 2014 | Blakeslee DD-60 Stand Mixer
Drive Shaft stopped kneading dough
To give the mixer strength it has planetary gears. Something may be wrong in the gear section
Nov 26, 2013 | Bosch 800-watt Universal Plus Mixer with...
When raised to do whipping my professional 550 hd mixer attachment does not scrap the bowl to mix properly
You can adjust the mixer bowl up and down slightly. If you lower your bowl and look at the back you will see a little screw, it looks like a flat head screw and it is on the "neck" of the mixer.
You can raise and lower the bowl by adjusting this cam screw. You can tell that your bowl is adjust correctly by attaching the flat beater and put a dime in the bottom of the bowl, the beater should just barely touch the dime and move it around the bottom of the bowl.
The beater will not scrape the sides of the bowl, if you are wanting the sides of the bowl scraped I would recommend the Flex Edge Beater made by KitchenAid which is basically a flat beater with a rubberized edge which will scrape the side of the bowl as it rotates.
Here is a link to the flex edge beater on our website: http://www.mendingshed.com/kfe6l.html
Let me know if you have any other questions.
Thank you,
ColleenCustomer ServiceMendingShed.com800-339-9297
Apr 04, 2013 | KitchenAid New Professional 5.5 QT...
Hobart N50 Stand Mixer Logo
478 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
