I am needing to remove my gear, worm follower on my KA 6qt pro. But the shaft has to be removed first & I don't know how to remove it.
Beth,
First you should have the parts manual (Pt No. 8212278 Rev D) in your possession. You can download a PDF file from Kitchenaid, if you don't have it. Once you've have the manual, turn to page 4 - Case, Gearing and Planetary Unit.
I'm also assuming you're able to disassemble the mixer and access Illus. No. 4 - Transmission Housing. You want to remove the cover and place to the side. (Be careful of all the grease inside the cover and on the gears)
Next wipe the gears and shaft clear of the grease.
You want to get to Illus. No 10, so first you must remove Illus. No. 7 - Retaining Clip using a pair of external clip ring pliers.
Next, lift Illus No. 8 - Bevel Gear off the shaft.
Next, remove Illus. No 9 - Retaining Pin. That will finally allow you to lift Illus. No 10 - Worm Gear Follower of the shat.
I hope this helps.
I don't have a parts manual but looked on Sears for the parts diagram. I was down to the shaft & once I wiped the grease off my husband found the snap ring (which I broke when removing). But we got the pliers & a new snap ring at the local hardware store & I got it put together a few days ago (after replacing the worm gear follower). So far, so good. I can't wait to get a mixer that will be as "tough" as it advertises.
