Question about KitchenAid K45SS Classic Stand Mixer
HOW DO YOU REMOVE THE PLANETARY ON A KITCHENAID MIXER MODEL KP26M1XGR3
Posted by davechance on
Howard Lincoln
  • 235 Answers
Hi DAVE, Merry Christmas & Happy New Year! The inspection and troubleshooting of the inside of your mixer is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case: KP26M1, and select one of the first two files listed under Parts List (47) (The first file, KP26M1XAZ4.pdf (304.18 KB), is for a -4 series model and the second file, KP26M1XAZ5.pdf (724.41 KB) is for a -5 series with slightly different insides, so make sure you have the correct Parts List manual.) (For the purpose of this solution I will use the 5 Series Parts manual. Substitute accordingly if you have a 4 Series model.)
Turn to pages 4 & 5, titled “Case, Gearing and Planetary Unit”, which provides and exploded view for the disassembly and reassembly of your mixer, along with all the parts.
(1) Remove your KA Decorative Trim Band (Illus No. 3) by removing one (1) screw (Illus No. 22).
(2) Remove the four (4) head cover screws (Illus No 14) and lift of the mixer head cover (Gearcase Motor Housing top, Illus No. 1).
(3) Next, remove the two (2) screws (Illus. No. 14) securing your (Speed) Control Assembly (Ilus. No. 19) so you can move the Control Assembly out of the way. This will allow you better access to the Transmission Housing (Illus. No. 4).
(4) Remove the four (4) Transmission Housing screws (Illus. No. 14). Carefully lift the Transmission Housing off the base. The Transmission Cover Gasket (Illus. No. 6) may come off with the Hosuing or remain on the base. (Recommend reordering a new gasket if damaged)
(5) Remove all grease from inside the transmission cover and off all your gears. (This is the messy/fun part. While cleaning away the current grease, be sure to be keep and eye out for metal ‘filings’ that may be suspended in the grease.
(6) Remove the Worm Gear drive assembly (Illus. Nos. 16, 17, and 18) and set aside.
(7) Remove Retaining Clip (Illus. No. 7) from the Planetary shaft.
(8) Remove (lift up) the Bevel Gear (Illus. No. 8) from the Planetary shaft. This may require a little friendly persuasion, but it should eventually slide off the shaft exposing the Retaining Pin (Illus. No. 9).
(9) Remove the Retaining Pin. It should come out easily in either direction.
(10)You can remove the Worm Gear Follower (Illus. No. 10) but once the retaining pin is removed, you should be able to push the Planetary Assembly (Illus. No. 28) down through the Lower Center Bearing (Illus. No. 12). A few taps with a soft faced mallet may be required.
You now have access to the Planetary gear and Agitator Shaft Assembly (Illus. No. 34). Apply the same techniques to remove/replace any components from the Agitator shaft.
Assemble in reverse order above.
Continued in "Comments" - hslincoln
Posted on Dec 28, 2009
  • Howard Lincoln
    Howard Lincoln Dec 28, 2009
    Continuation from above:
    With the innards of your mixer exposed, now is a good opportunity to check for excessive wear of the gears, particularly the bevel gear (my wife’s mixer’s bevel gear lost a tooth and that’s why I now know how to take them apart). Use a food-grade grease that you can order online (although I’ve seen automotive bearing grease used too – your call), when you repack the transmission housing.
    Here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com. Prices can vary widely between vendors, so do your comparison shopping.
    Finally, here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer. The mixers displayed in the links may be different than your KA model, but the principles are the same.
    Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer, should you decide to go that route.
    Good luck and have fun. I hope this helps. Howard, Burke, VA
    If this solution was helpful, please rate it, thanks! – hslincoln
How do I replace the speed control lever on a kitchenAid artisan mixer
Remove back cap, remove white wire and black wire from lower corner of speed control plate, both on same side on adjacent terminals. Remove the gasket thing at the back as well.
Remove chrome drip ring from around planetary, knock pin out of planetary and remove the planetary.
Flip upside down on a towel and remove pedestal by taking out hinge pin (1 locking screw from underneath inside pedestal)
Remove all screws from bottom side of gearcase, 5 around planetaty, 2 in the middle and 2 at the back.
You can now seaparate the gearcases to get to the speed control lever which is held on by 1 screw.
Feb 15, 2015 | KitchenAid KSM150PS Artisan Series Stand...
Kitchenaid mixer K45SS only has one speed, slow. Have taken apart and regreased the machine. I plugged it in while the planetary head was off and it went through the speeds as normal, but as soon as
Did you clean the are around the variable-speed control lever?
Please be sure to unplug the mixer BEFORE disassembling the mixer.
http://www.ereplacementparts.com/kitchenaid-k45sswh0-classic-stand-mixer-parts-c-114958_114959_115060.html?page=4
http://www.ereplacementparts.com/article/11983/How_to_Replace_the_Speed_Sensor_and_Control_Board_on_a_KitchenAid_Pro_6_Mixer.html
Jan 07, 2014 | KitchenAid K45SS Classic Stand Mixer
How to remove stuck bevel gear off planetary shaft in KitchenAid 6qt professional mixer
That should just lift off, I'm not familiar with your particular model but all the bevel gears I have seen just drop onto a pin that is just a push fit through a hole in the shaft.
Oct 26, 2013 | KitchenAid KP26M1X Stand Mixer
Kitchenaid mixer leaking oil
Get a copy of the Repair Part List for your model at Kitchenaid.com
Grease inside the Planetary Assembly (the shaft is tight fit to the Planetary
plate at the factory and is not designed to be taken apart, so do not use
any hard object such as a screwdriver to separate them) over times can
turn to liquid and leak down the bowl. Removing the Planetary assembly
and adding Kitchenaid Food Grade Grease is not a task for a novice.
To properly remove the Planetary Assembly, you must work from inside
the Transmission Housing: Remove in this order: Retaining Clip(25), Bevel Gear(21),
Retaining Pin(18), Worm Follower Gear(19). Use a soft mallet to tap out the Shaft
of the Planetary Assembly(15). Re-assemble it in the reverse order.
Note: The Bevel Gear is extremely tightly fit on the shaft, and a pin punch
must be used to remove from the shaft.
Jul 14, 2011 | KitchenAid KP2671 Professional 6 Series...
Where do I get a planetary assembly for a Kitchen Aid mixer? The model # is KP26M1XMR and the part # is 9708036
There is a dealer on eBay selling it right now (New). Search for
KitchenAid Stand Mixer Planetary Assembly White 9708172
May 01, 2011 | KitchenAid KP2671 Professional 6 Series...
How do you take apart the KitchenAid Mixer K5SS to get at the gears? The motor runs but the beater doesn't go around. I have an exploded view, but it isn't clear how to begin disassembling the planetary.
It quick terms, first remove the head. Take off the band, this is where the two halves join. Undo any screws holding the halves together. Remove the pin holding the planetary in place. Remove the trim disc. The planetary assembly lifts out but you may need to work around it carefully lifting it a little at a time.
Sep 28, 2009 | KitchenAid K5SS Heavy Duty Commercial...
Adding oil to the k45ss
Hi. Goto www.kitchenaid.com enter your model # into the search window, look for the parts catalog for your mixer. Download this file. It will come in handy if you ever need to order parts, and will give you an overview of your mixer.
Goto www.mendingshed.com and locate the free Kitchenaid Service manual. This manual contains all of the info needed to service your mixer.
Finally, your mixer uses grease for lubrication. When you see oil dripping, it means that your mixer needs to be re-greased as the oil is separating from the grease base. I recommend Chevron FM ALC EP-2, this is a food grade grease that is non-toxic should you get some of it's oil in the mixing bowl at a later date. Remove the old oil and grease remnants from the mixer, including the planetary unit. You can remove the planetary by tapping the tapered pin out of the shaft. Clean and re-grease. After you've completed these tasks, run the mixer for a couple of minutes every week to keep the oil in suspension. This will extend the life of the grease.
Good luck! If this solution has assisted you, please rate it. ricardok45.
Mar 29, 2009 | KitchenAid K45SS Classic Stand Mixer
Hobart N50 / KitchenAid Model G: how do i remove planetary?
you need to remove all the back screws then if it doesnt come tap it with arubber mallet it may be seized on
Nov 19, 2008 | Hobart N50 Stand Mixer
KitchenAid K45SS Classic Stand Mixer Logo
735 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Colin Stickland
Colin Stickland
Lee Hodgson
Lee Hodgson
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
