Panasonic KX-A115CE changing pulse to tone dialing
Can anyone tell me how to change it? There is an option ''Setting Base'' on the handset and when I enter it it says ''Input Command'' but I have no idea what should be entered.
Thanks a lot!
Re: Panasonic KX-A115CE changing pulse to tone dialing
Can anyone tell me how to change it? There is an option ''Setting Base'' on the handset and when I enter it it says ''Input Command'' but I have no idea what should be entered. Thanks a lot!
Dialing mode If you cannot make calls, change this setting according to your telephone line service. The default setting is "Tone". "Tone": For tone dial service. DONOT set to "Pulse":
[MENU]#120
Select the desired setting. which is
tone
page 15 of ftp://ftp.panasonic.com/telephone/om/kx-tge432_en_om.pdf
Touch the following keys: Menu 0 5 1 and then select 1 (tone, the factory default) or 2. Then Save (a softkey with the label in the LCD screen) and Off (opposite Talk on the keypad).
Here's what the manual says:
Changing the Dial Mode (Tone or Pulse Dialing)
(HS1 only)
Your phone can communicate with the telephone network in two different
ways: tone dialing or pulse dialing. These days, most phone networks use a
method called tone dialing, so your phone comes programmed for tone dialing.
If your phone company uses pulse dialing, you need to change your phone's
dial mode. If you don't get a dial tone or can't connect to the telephone
network, follow the steps below to modify your phone?s settings:
With the phone in standby, press and hold [cid/menu].
Press [vol/ / ] to move the pointer to select DIAL.
Press [select/channel] to set the phone to pulse dialing.
Press [end].
Return the handset to the base. The handset communicates the new
setting to the base, and the base activates the setting on any other
handsets.
Hope this helps out.
K
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
