20 Most Recent Panasonic KX TG1000N Cordless Phone Questions & Answers
When I searched for your model,the 'N' model did appear on the site although it does not say it in the link I am providing.If you need further help,just comment back here and i will get an autolink to your post.Good luck! Greg
http://www.retrevo.com/support/Panasonic-KX-TG1000N-Telephones-manual/id/2914bh726/t/2/
Panasonic KX... | Answered on Oct 13, 2010
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Panasonic KX... | Answered on Sep 10, 2009
the hand set of kx-tg1000n locked at c533.....pleas help me
For KXTG1000 only
  • The base unit must be connected to the AC adapter and the power must be on
  • Press the following sequence of buttons on the base unit: * * 3 3 5 7 8 2
  • When the display reads "Enter Base ID", deregistration has been completed successfully
  • For KXTG1050 only
  • Disconnect the AC adapter
  • Hold the Locator button down while you plug in the AC adapter
  • When the Power light flashes, release the Locator button
  • Immediately press and hold the Locator button again, and release when the In Use light flashes
  • The Charge light should flash for 4 to 6 seconds and then turn off
  • When the Charge light stops flashing, press Locator again
  • In about 20 seconds, the handsets will deregister. When the displays read "Enter Base ID", deregistration has been completed successfully.
  • Panasonic KX... | Answered on Dec 21, 2008
    I would suspect that you need to de-register both 3 and 4 at the same time before re-registering them. This probably will not work if the base unit still thinks phone number 2 is out there somewhere. It would need to be de-registered as well for the others to move up a notch. I did read the process for de-registering somewhere on the web, don't remember where, just that it involves removing/installing the battery and punching some buttons.
    Panasonic KX... | Answered on Nov 11, 2008
    well clea the base, you didnt leave much for us to help you on mate.
    Panasonic KX... | Answered on Jul 15, 2008
    Caller ID will only be available if you subscribe to that service from your telephone provider. Some PBX systems do not provide compatible Caller ID information. The KX-TGA810E handset will not display any Caller ID information if the telephone company Caller ID format is not in the expected format.
    The KX-TGA810E is an add-on handset for certain Panasonic cordless phone systems, including the KX-TG8100. For more information about the handset, see https://www.manualslib.com/manual/650310/Panasonic-Kx-Tga810e.html#product-KX-TGA810E . The KX-TG8100 manual section on Caller ID is available here: https://www.manualslib.com/manual/117913/Panasonic-Kx-Tg8100e.html?page=25#manual . The complete manual for the KX-TG8100 is https://www.manualslib.com/manual/117913/Panasonic-Kx-Tg8100e.html .
    I hope this helps.
    Panasonic Lands... | Answered on Sep 14, 2019
    Google (Panasonic)(KX-DT521)(manual) without parens.
    Panasonic Lands... | Answered on Sep 12, 2019
    Unfortunately, I can't find a manual for the KX-30P available online. I did find a manual for the Panasonic KX-20P, ftp://ftp.panasonic.com/homeoffice/om/kx-20_en_om.pdf . I suspect the 3 hole punch did not change significantly between models. Panasonic also has a manual for the KX-32P (2 or 3 hole punch), ftp://ftp.panasonic.com/homeoffice/om/kx-32_en_om.pdf . Other Panasonic home office product manuals are currently here: ftp://ftp.panasonic.com/homeoffice/om/ .
    I hope this helps.
    Panasonic Lands... | Answered on Sep 11, 2019
    Panasonic KX TG1000N Cordless Phone Logo
    16 questions posted
    Top Panasonic Lands Phones Experts
    Ekse
    martin hogg
    guyvstewart
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
    View Most Popular
    • Panasonic Lands Phones
    Most Popular Question
    kx tg1000n new handset 1
    • Lands Phones
