AT&T Blackberry Curve 8300 Smartphone Logo
Posted on Oct 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Before I go to take a picture the camera is seeing the red and blue subject which is also very fuzzy and wavy. When I transferred the photos I took to my computer, the roxio page said they were corrupt.
Anonymous
Level 3:
Brigadier General:
  • Master 7,752 Answers
  • Posted on Jan 30, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
7752
Questions
Helped
1416243
Points
13016
You need to reflash the OS on the phone you should take the battery out first then connect it via the usb cable to the laptop/pc you are using then open the blackberry desktop manager,click on the apploader, then install the OS.
pls not that when u click on the apploader the pin should be PIN:UNKNOWN you make need to do this like 4x before the pc sees the pin:unknown but it will work once it see the pin:unknown you can re-insert the battery and continue with reflashing the phone
this should correct the camera issue most likely it is not the camera that needs to be replaced just the OS need to reinstalled.
2answers
Black fuzzy spot in pictures
Have you verified that it is in the picture and not the screen by transferring the photos to your computer?
You way have some dust or lint that got on the lens if the photos have that problem.
Just take an eyeglass cloth and spray wither eyeglass cleaner, or just a little dab of alcohol and then wipe the lens clean.
How do I set the resolution on my Canon SD850?
The instructions for changing the resolution are on page 30 of the manual.
If the pictures are fuzzy, increasing the resolution won't help. The most likely causes of fuzzy pictures are as follows
1) Focus. Check to make sure the focus is on the subject. If something else in the picture is sharp while others are not, then the camera may have focused on the wrong subject.
2) Subject motion. If moving objects are fuzzier than stationary objects then you need to use a faster shutter speed (or flash).
3) Camera motion. Just because the camera is on a tripod doesn't mean it doesn't move. One philosophy says that if a tripod is light enough to be carried then it's not sturdy enough. For a compact camera like the SD850 that likely isn't the problem. However, you can still shake the camera when you press the shutter release button. Try setting the self-timer. This allows time for the vibrations to die down before snapping the picture.
In your particular case, I think we can assume that the subject isn't moving, so #2 doesn't apply. To assure proper focus, make sure the painting is flat and perpendicular to the lens axis. If the painting is tilted relative to the camera, then different parts of it will be at different distances and the camera won't be able to keep all of it in focus.
Also, make sure the front of the lens is clean.
Fuzzy pictures
You can open the lens for exposure by aiming the camera at your subject and pressing the shutter button halfway before you take your picture. This also triggers autofocus based on your camera settings. After this, you can aim your camera more precisely and press the button all the way to take a photo.
1helpful
What is the best settings to take pictures daily.. i find my pictures are quite fuzzy and blured
For every photo shooting, it is recommended to set all values and settings to automatic so the camera sensors will adjust according to the surroundings, focus, subject, and light conditions. Also for a tip to minimize blurry captures is to lower the ISO value and to allow at least a fraction of a second before moving the camera away from the subject after clicking the shutter.
2answers
Red eye on sanyo digital camera xacti,always theres a red eye when taking pictures,i already adjusted everything,still occuring red eye.
Do you mean your subject's eyes are showing "redeye"? This is a common problem with cameras that have the flash very close to the lens. Almost every photo editing program has a tool to remove red-eye. Check your computer to see what you have installed. In the future, most cameras have a red-eye flash setting which shoots a short flash before the main flash to close down the pupils in your subjects eyes to eliminate red-eye. You could also turn up the lights in the room...sometimes that helps.
1helpful
2answers
Photos are fuzzy. At the time it takes 52 picts. a round. Would they be sharper if I reduce the picts?
Hello MaryRoth,
Photos are fuzzy due to many reasons and the main two reasons are that the subject is out of focus or the subject or the hand shake during the time of taking the snap.
Please make sure that you select appropriate picture modes (Macro, Portrait, Landscape etc..) when taking snaps. Make sure that when you press the click button half-a-way (known as AE mode), the subject is still in focus.
Try using a Tripod stand in case the hand is not steady or try increasing the shutter speed if its an SLR camera. That should help.
Let me know if that works.
Regards,
Srinivas
Apr 27, 2009 • Cameras
When taking picture the LCD screen shows red fuzzy color
are these red fuzzy colors actually on photos or just on lcd i think u r gettin them on photos also if thats the case ur CCD is gettin faulty u cant help it changing the CCD is not recommended bcoz it will cost u like new camera u can buy a new one i think
Green screen with red and blue wavy lines
This is "NOT" meant as "expert" advice...as this is not my area...HOWEVER...I see no one has answered this yet...AND I got some good help from here a year or so ago that worked for me!
When I had a similar "green screen" problem with my SONY projection tv...the guy helped me by having me make "MINOR" adjustments to the red/blue/green etc knobs behind the panel. These were three small black plastic pieces and needed less than a 1/16 of an inch adjustment...try adjusting one at a time and giving it few seconds after each adjustment. It worked for me..at least for a while (till my wife gave it away to a friend because it was "too big"...ah! women!!! LOL)...hope this helps. (NON-expert help!)
Green Background with red wavy lines
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
2answers
Nikon S60 LCD screen turned red and pictures now turn out wavy
If you have the receipt and store information and/or warranty registered, you may want to return for refund or exchange.
Top AT&T Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
