D-Link DSL-G604T Wireless Router Logo
Posted on Sep 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am trying to set up security on my G604T, either WEP or WPA. I follow the prompts and insert network key or password and it asks me to save and reboot. I see no save button so i click apply, close the application and turn the router off for a bit, then on. The security psetup has then reverted to "none"! What am I doing wrong?
Anonymous
Level 2:
New Friend:
  • Expert 40 Answers
  • Posted on Dec 09, 2009
Anonymous
Expert
Level 2:
New Friend:
Answers
40
Questions
0
Helped
8146
Points
111
You need to go to the System tab and then go to Tools, then choose save and reboot.
What is a security key
WPA (Wi-Fi Protected Access) is an advancement over WEP (Wired Equivalent Privacy). While connecting to a home network, you are often asked to insert a WPA key or a password to which users often ask, "How Do I Find My Computer's WPA Key?" WPA stands for Wi-Fi Protected Access. It is a standard security protocol implemented by Wi-Fi alliance to secure wireless computer networks. WPA standard is advancement over(Wired Equivalent Privacy) Wep is standard that had several security issues. WPA implements most of the IEEE 802.11i standard and provides greater security than WEP.
While connecting to your home network, you are often asked to insert a WPA key. This WPA key is either located in the modem or in the router you are using. In order to find your computer's WPA key, follow the steps given below:
How to find your computer's WPA key Step 1: First of all, you need to launch an internet browser. Press "Windows + R" keys to open the "Run" prompt and type "iexplore" without quotes to open Internet Explorer. You can also type "firefox" to open Mozilla Firefox. On the address bar at the top, type http://192.168.1.1 (Belkin routers use 192.168.2.1 as the default IP) and press "Enter" key.
This address belongs to your wireless modem or wireless router to which you are connected.
Step 2: A window asking for username and password will appear. In the username field, type "admin" without quotes and in the password field, either type "password" without quotes or leave the password field blank. Press "Enter" key to continue.
If password is correct, you will be redirected to the modem/router's "Settings" page, otherwise, you will have to reset the modem/router. Check beneath the modem/router or check the manual for correct password.
To Reset a modem/router, locate a small hole at the back of the modem/router and insert a pin to press the switch inside it. Keep the switch pressed for about 20-30 seconds after which the modem/router will restore the settings to "factory defaults" and reboot itself.
Repeat the step 2, in order to gain access to "Settings" page.
Step 3: On the modem/router's "Settings" page, find "Wireless" option. Click the "Wireless" link to populate the wireless settings. Now, locate and click the "Security" or "Advanced Security" option.
On the security page, you will find "Network Authentication". Different options available under the Network Authentication menu are open, shared, WEP, WPA, WPA2, WPA-PSK, WPA2-PSK, etc. Select either WPA or WPA2, to find your computer's WPA key and insert this key when asked for.
If in step 2, you had reset the modem/router, you will not find any WPA or WPA2 key, and you will have to manually assign one. Select any of the WPA-PSK or any other authentication and assign a key to it. A key can be 8-63 long. For minimal security, you can choose 8 characters key, like "iN\/5R92". For maximum security, choose 63 characters key like, "sJ0esmoU2cBD\m+oMp$nrXj5XPVRTvVA5fpwGSGI\RVz4RdQ7V3y\l$P1NrT9Be".
After you have assigned a key, save/apply the changes and reboot the modem/router.
Note: The procedure shown above is common to most of the modems/routers. If this doesn't apply to you, check your modem/router's manual to find the wireless security option.
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
How do i connect to internet with ps3, wireless, what is a wpa key?
WPA stands for Wi-Fi protected access. It is a standard security protocol implemented by Wi-Fi alliance to secure wireless computer networks. WPA standard is advancement over WEP (Wired Equivalent Privacy) standard that had several security issues. WPA implements most of the IEEE 802.11i standard and provides greater security than WEP.
You can correct this problem by entering the WPA Key into your PSP's Network Settings. But before you do that you need to know what your WPA Key is...
To reset a Linksys modem/router or Belkin one, locate a small hole at the back of the modem/router and insert a pin to press the switch inside it. Keep the switch pressed for about 20-30 seconds after which the modem/router will restore the settings to "factory defaults" and reboot itself.
For minimal security, you can choose 8 characters key, like "iN/5R92". For maximum security, choose 63 characters key like, "sJ0esmoU2cBDm+oMp$nrXj5XPVRTvVA5fpwGSGIRVz4RdQ7V3yl$P1NrT9Be".
When i connect i get this message' your wpa key you entered may not be correct"
2answers
My internet is unsecure how do i secure it? wireless dsl-g604t
1.Check your wireless setup and see if the wireless is on.
2. do ipconfig / all at the command prompt
3. test the router by setting up the router by MAC address.
4. Go into security settings ( router) an create key( WEP/WPA )etc.
2answers
I have a D-Link DIR 615 wireless router i am trying to connect my daughters DS to the wifi but it keeps asking me for a WEP KEY???? i dont know the wep key i put the serial number in and the password but...
WEP KEY
WPA KEY
When you will make WEP key then you have to put this key on your pc first for connect to internet. It is very easy steps & your network will make secure.
First check your network option also.
Right click on your network then you see the property then go to security See dropdown menu If you have wep key then follow these steps if you did not see thi.
WPA is same as WEP
(WEP)
You need to sign in your router first.
1.open a web-browser such as Internet Explorer and enter the IP address of the router (192.168.0.1)
http://192.168.0.1/
2. Select "Admin" from the drop-down menu and then enter your password. Leave the password blank by default.
Now you can see your D-LINK webpage where you find your wep key.
Clik setup then wireless setting
Now you see on this page
1. Wireless Security mode then drop-down-menu Set Enable WEP
2. Authentication - Choose Shared Key.
3. WEP Encryption - 64 Bit.
4. Key Type - HEX
5. Default WEP Key - WEP Key 1
6. Now Make a key( You can choose any password but remember only 10 charcters allowed)
7. Now Save setting. then your router gonna boot up make sure let it boot. It connected after 5 minute.
You should write your password in paper first then you will have to add this key into your pc. network.
You can not connect internet because you have to put these Key(password) into your pc first.
Go to your network connection in your pc Choose your network
Or
You see two computer( internet icon) on the desktop
Right click then connect to network then you see so many network & your network ( Which you create).
Right click on your network then you see the property then go to security choose wep key then put the password(KEY).
WPA
1. Wireless Security mode then drop-down-menu - EnableWPA
2. Clipher type -TKIP
3. Passpharse - create own password here( don't put any personal info there)
Save setting
Device restart.
Now check Network status. Its working now.
Follow youtube video
3answers
I cannot set up wap security for wireless d-link g604t. everyone can connect without password.
www.cstuff.co.nz/.../D-Link/DSL-G604T%20GenII%20Installation%20Guide.pdf -
user manual above it shows you how to do it in the security section. Basically you loginto the router give logon and password, then go to security and set a WAP/WEP "Key" All in manual above..
Set up a non wep password
Hi Friend,
Please follow the steps;
1.Open the router page(192.168.1.1)
2.Enter the username and password(default password is admin and leave the username blank)
3.Click Wireless and then fill the sections as mentioned:
Wireless-Enabled
Wireless Netowrk Name-As per your choice
Wireless Channel-6-2.442GHz
Wireless SSID broadcast-Enabled and click Save settings
4.Click Wireless Security and fill the sections
Wireless Security-Enabled
Security Mode-WPA pres-shared key (as you want non wep password)
WPA Algorithm-TKIP
WPA Shared key-Minimum 8 and maximum 64 digit password
Group Key Renewal-3600 and click save settings
Turn off the router for 30 seconds and turn it on after that. Now you have a non wep secured network
I hope this will resolve the issue.
Regards
Chiranjeet
Connection is asking for network security pin
Network Security pin is the WEP or WPA provided by your service provider, while configuring the Router. Please follow the below steps to get the WEP key.
1. Click Start -> Run -> type "cmd". Click OK. Command prompt screen will popup.
2. In the command prompt type "ipconfig" hit Enter.
3. Please make note of default gateway address (Eg. 192.168.1.1)
4. Open internet browser and type http://<default gateway address> (Eg. http://192.168.1.1)
5. You will be prompted to enter Router login Username and Password. (provided by service provider). Enter the username and password.
6. You will see the Router configuration page, then select the Wireless Tab; there you will see WEP / WPA key.
Thanks n Regards
Rizwan
2answers
Need to set up wep or wpa key
Hi, this link I provided to you is useful for you.
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3696
I have a wpn824-2 and I am trying to set up a connection from my lap top. It is asking me for a network key or wep key. Where do I find it?
You can get the WEP or Network Security Key from the Router.
Login to the Router as follows (make sure that it is connected to the Computer using LAN-Wired connection):
1. Start the Web Browser like Internet Explorer or Firefor or Safari.
2. Type 192.168.1.1 as the URL.
3. Type "admin" as user name and as "password" as password.
4. Go to the "Wireless Settings" option.
5. Set the Wireless Network Password (either WEP or WPA key) will be listed next to Security Encryption.
You may also use any third party utility to get the Wireless Security key save in the Computer (in which wireless connection is working and key is saved).
Good Luck!!!!!!!!!!!!!!!
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
