Samsung DVD-L200 Portable DVD Player with Screen Logo
Posted on Sep 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My AC jack on the unit does not charge. How
My AC jack on the unit does not charge. How difficult is it to replace?
Anonymous
Level 3:
Brigadier General:
  • Master 4,090 Answers
  • Posted on Sep 28, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
4090
Questions
0
Helped
1184387
Points
12747
Very! It is soldered into the motherboard on very fine tracks. It might also be difficult to get the right sized jack for this.Unless you have a desoldering kit and a needle point tip for the soldering iron you wilol have trouble doing it. Also if you overheat it with the iron it will damage the circuit. Best to have a professional try it.
Please rate our help++++Thanks for using FIXYA
1helpful
Hewlett Packard Compaq Presario CQ56 power/charge light blinking orange & will not charge. I replaced the charging unit but it is dtill not charging. What could the problem be?
You need to get the DC Power Jack Either Repaired or replaced...this is the "female" port where your AC Power cord plugs into.. To Repair the current DC Jack...First you'll need to look closely at the Positive posts to see that they are not broken.. If visibally ok.. then you can look at the Solder Connections.. they will need to first be Desoldered.. Cleaned, then Resoldered back in place.
2helpful
2answers
2helpful
My Acer aspire 4935 is not recognizing the AC adapter. When ever I shutdown the system and connects the AC adapter, it works and the charging LED lights up. Once I press the power button to boot the...
Problem description:The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
When the laptop is turned on, the battery charge LED goes off even if the adapter is still plugged in.
Possible cause:1. AC power adapter failure.
2. Battery failure.
3. Broken/loose power jack.
4. Motherboard failure.
Possible troubleshooting steps and repair solution:1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
http://www.chargerbuy.com/replacement-acer-aspire-9400-ac-adapter-19v-3-42a.html
2. There is a slight chance that you have bad battery. Test the laptop with a know good battery and replace the faulty one if needed.
3. The battery charge problem could be related to the power jack. Maybe the jack is broken or not making good contact with the motherboard. It is necessary to remove the motherboard and take a closer look at the power jack. Resolder or replace the jack if needed.
4. If the power jack is in a good working shape and new power adapter with battery do not fix the problem, most likely you have a faulty motherboard. Replace the motherboard if needed.
1helpful
I bought new universal adapter for asus laptop and it charges batery just when laptop is turned off
Problem description: The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
Possible cause: 1. AC power adapter failure.
2. Battery failure.
Possible troubleshooting steps and repair solution: 1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
Reference: http://www.chargerbuy.com/blog/battery-charges-only-when-laptop-turned-off/
ASUS laptop AC Adapter
Sometimes the Adapter Charges other times Doesnot, and now finally out, cant charge!
Possible cuase:
1 AC adapter failure
2 Power jack failure
First replace it with another working charger, see if the problem gone. If not, there may be strong possibility that the power jack was broken.
Here below are some common symptoms of a bad charger.
-The laptop only runs when you keep the power cord in a certain direction.
- The laptop only runs on battery power.
- The laptop will not charge the battery.
- The laptop switches from AC power to battery power intermittently.
- The unit suddenly shuts off
- Sparks come out of the back of the laptop.
Reference: Dell Latitude D620 Charger
1helpful
Selector stays on heat
find a used unit(cheaper) and have an experienced mechanic replace it. Hopefully this helps!!
1helpful
Ac power problems
For $75.00 bucks I wouldn't even open it up... lol Thats a good deal if they do a good job. Thats a fair price too I charge like $65 - $80 and hour depending on what is being done. remembering of course we often in actuality often work on something for 6 hours, and only charge 2 - 3, because a job is worth what a job is worth.
2answers
Will not run on AC power or charge battery
If issue occurs with a known good AC adapter then next is replace the motherboard. Around $150 on EBay
Spc340 fails after 30 seconds. Is there a battery to replace ?
it sounds like the charging jack in the cradle has gone bad they can be fixed, you have to disassemble the mount and the resolder the jack, it is a difficult task i would rate it about a 9 to a 9.5 out of 10 on difficulty scale, more than likely it will not be worth the frustation to repair, vs replace.
1helpful
Camcorder won't charge up
Its problem of DC-IN jack where you hook ac charger. This jack needs to be replaced.
Let me know exact model of camcorder to provide you part number of DC-In jack.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
