20 Most Recent HEWLETT-PACKARD Compaq Presario CQ56-110US Notebook Questions & Answers
I am trying to help
NO OS STATED by you, makes help impossible. (near) CQ56 (2010 PC) It looks like Windows XP is dead? that it? Or w7 as many had, it matter, due to the file structures are not the same. at all. the fix is easy if you have boot disk or cd or stick the dos command are easy to command, for fixing any lost boot files. what makes you think the HDD is even good. I'd not. not ever. the hp links are dead to this PC but using google site search the good is there still and tells you the F11 key works you boot the pc (turn it on) and hammer the F11 key and the recovery partitions run. if not the HDD is corrupted. the F11 key if working pops a recovery page pick startup files repair,. end story if the hDD is bad the story gets longer,.. the HP site tell me it was W7 new, (did you upgrade it to 10 free last year, we cant guess what is there or how it got there, see?) I run knoppix boot disk /stick and run disk test here http://pcdied.com/brick-dead.html#Knoppix recovering any OS this way, with a bad HDD is a wasted day. there is no reason to do that. run DISK SMART and TEST THERE. here are my recover pages. see startup repair, this fixes the file you said were missing. mine has and automatic repair option startup-settings-033ev5fxk2obj5u2llm5dinp-1-0.png
7/30/2017 12:32:16 PM • HEWLETT-PACKARD... • Answered on Jul 30, 2017
Turn wireless capability
There should be a button just above the minus key (to the right of the 9 key)that reads F12 which you can press in conjunction with the Fn key ( to the left of the Space Bar key). Doing this should either activate or deactivate the wireless networking on your laptop. White indicates that the wireless is On and Amber indicates it's Off. Below is a link to the User's Guide. http://h10032.www1.hp.com/ctg/Manual/c02474886.pdf#page22
7/13/2014 11:23:43 PM • HEWLETT-PACKARD... • Answered on Jul 13, 2014
How do i press the f12 key without turning the
You can set the function keys to act as "function Keys" or to work on the pictures that are printed on the function keys. To change it you need to enter the BIOS by pressing a key during the initial boot up of your computer. It will show you on the screen what to press as you boot it up, you usually only have a few seconds. If you don't know how to do it for your computer check your owners manual for how to enter BIOS, once in BIOS look for a setting to "change action key mode" or a reference to function keys. Change this setting then save changes and reboot your computer, that should solve your problem.
11/20/2013 7:18:49 PM • HEWLETT-PACKARD... • Answered on Nov 20, 2013
Speakers audio
This would indicate an issue with the streaming source. Try another streaming source and check issue. You may need certain plugins etc. to play video/audio.
11/16/2013 9:48:48 PM • HEWLETT-PACKARD... • Answered on Nov 16, 2013
Pink screen
Is it Intel or AMD? Do you have the correct graphic card driver installed?Go here, http://www8.hp.com/us/en/drivers.html locate your product and download the right driver..
11/14/2013 3:37:16 AM • HEWLETT-PACKARD... • Answered on Nov 14, 2013
Reset bios password
there is linux utilitysoftware out there that you can boot and find or reset the bios password or you can disconnect the bios battery for 15 seconds to reset the bios to default.some laptops have a removeable battery you can unplug but most cmos batteries have leads that are soldered onto the motherboard.you would have to use a soldering iron to melt the solder on the positive lead and lift it away from the board.after 15 seconds you can resolder it back in place.
8/21/2013 12:49:21 AM • HEWLETT-PACKARD... • Answered on Aug 21, 2013
Screen turns pink after login
While in Safe Mode....Go to HP.com, Support, Drivers.... Download the latest video drivers, including the "Chipset" drivers. Then, uninstall all video drivers by going to control panel, (System, Device Manager)Reboot system, hopefully Windows will install the correct drivers upon reboot.After reboot, re-run the new drivers
3/13/2013 3:36:32 PM • HEWLETT-PACKARD... • Answered on Mar 13, 2013
I would like to know if my presario cq 56 can be recharged by other means than ac plug in
The laptop can be charged using the mains charging adapter.OR From a 12v car charge adapter.Check out these from this WEB site.http://www.ebay.com.au/sch/sis.html?_kw=12V+Car+Motor+Power+Adapter+Laptop+Charger+to+20V+3+5A
2/4/2013 5:34:43 AM • HEWLETT-PACKARD... • Answered on Feb 04, 2013
Press the L key and LP appears
Try cleaning the keyboard. Has there been a spill? Damage? Worn out? Replace if necessary.
12/31/2012 7:32:35 PM • HEWLETT-PACKARD... • Answered on Dec 31, 2012
Hewlett Packard Compaq Presario CQ56 power/charge light blinking orange & will not charge
You need to get the DC Power Jack Either Repaired or replaced...this is the "female" port where your AC Power cord plugs into.. To Repair the current DC Jack...First you'll need to look closely at the Positive posts to see that they are not broken.. If visibally ok.. then you can look at the Solder Connections.. they will need to first be Desoldered.. Cleaned, then Resoldered back in place.
11/6/2012 1:58:57 AM • HEWLETT-PACKARD... • Answered on Nov 06, 2012
2answers
Startup gives the following warning: a cooling fan
Replace the cooling fan
If you do not the computer gets hot within minutes and will shut down automaticly
7/22/2012 6:47:49 PM • HEWLETT-PACKARD... • Answered on Jul 22, 2012
2answers
Cq56 reset bios password
You will have to remove the power cord, remove the batteryand remove the CMOS Battery that is located on the motherboard. On mostcomputers you will have to take the laptop apart to get to the cmosbattery. On some systems it looks like a silver nickel that you will needa small flat head screw driver to pop it out. On other systems it will beinside a vinyl covering and has a cable that plugs into the motherboard. Once you remove the CMOS Battery, let it sit for an hour or two then put itback in and put the laptop back together. Boot the machine and you'llprobably have to go into the Bios or System Setup because the system will haveforgotten the date, time and password.If the password is not reset then you might have to go and remove a Pin from the password jumper on the motherboard. I would consult the user manual and see how to do it.
5/3/2012 2:23:17 AM • HEWLETT-PACKARD... • Answered on May 03, 2012
HOW DO I FIND THE WEP KEY SO I CAN GET THE INTERNET ON MY PS3
the wep key number is on the router on the sticker it will say wep and then have a number with letters and numbers
12/24/2011 9:07:00 PM • HEWLETT-PACKARD... • Answered on Dec 24, 2011
My computer does nto detect
My guess is one of two... first that the USB drivers are corrupted or not properly installed. Go to the Control Panel, System, Hardware, Device Manager, Universal Serial Bus Controllers, if any of the controller ports or or hubs have a yellow or red mark on them, then try to delete and reinstall that device or driver. (described for XP, Vista or Win7 will be slightly different).
The other option is that you may have a USB hardware failure. You can add a PCMCIA to USB adapter for a few bucks.
8/16/2011 1:14:59 AM • HEWLETT-PACKARD... • Answered on Aug 16, 2011
Compaq cq56 xp instalation ...a problem has been
Don't install XP, install vista and all wil be ok, and will not dump in installation time
6/13/2011 7:24:51 PM • HEWLETT-PACKARD... • Answered on Jun 13, 2011
I just got a Compaq
cheak your usb port if you connect you connection than cheak your usb driver.
5/24/2011 5:22:18 PM • HEWLETT-PACKARD... • Answered on May 24, 2011
Where does the sim go
Hi tefordgal12,
I see you have a SIM that you want to use on your compaq system, I checked in you system specs online and it does not show that it has a 3g modem on it on the issue.
  • On all Laptops the 3g modem can be found inside the system, if you remove the battery you may see a slot for a sim card in the battery bay.
  • All Laptops have the 3g modem in the battery but not all Laptops have a 3g modem installed on it some may have sim slots but does not have the 3g modem installed in it
  • Call HP regarding this concern since they can answer our question most accurately if you give them the serial number of your Compaq Laptop.
I hope that the information I provided helps.
Thanks, have a great day.
4/7/2011 9:59:49 AM • HEWLETT-PACKARD... • Answered on Apr 07, 2011
2answers
When I attempt to go
Hi
sometimes the key or switch is up by the power switch
also try the FN+F2 keys
or have a look on or around the laptop keyboard usually a push key but sometimes a slide key
3/25/2011 8:24:23 PM • HEWLETT-PACKARD... • Answered on Mar 25, 2011
Can you tell me where
Hi
Could you try pressing the blue Fn bottom right and the F2 key
FN+F2
2/9/2011 7:55:04 PM • HEWLETT-PACKARD... • Answered on Feb 09, 2011
HEWLETT-PACKARD Compaq Presario CQ56-110US Notebook Logo
38 questions posted
Top HEWLETT-PACKARD Computers & Internet Experts
Paul Bade
Grand Canyon Tech
Grand Canyon Tech
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HEWLETT-PACKARD Computers & Internet
Most Popular Question
hewlett packard compaq presario cq56
  • Computers & Internet
