I had a tevion video sender which worked perfectly for years until the receiver packed up working. I have replaced it with a Logik sender and have tried every combination possible (plugging into Sky+ box, video and tv) and every channel on the receiver but am getting absolutely nothing. The old system worked with scart plugged into the back of the sky box straight away.
Could anyone please advise.
ps the red light is very strong on the transmitter but almost non existant in the receiver. Could this be anything to do with the problem as it cannot get a strong signal?
Thanks
SOURCE: hi, i have just bought a logik wireless av sender
I have bought an av sender so that I can watch sky on the tv in the kitchen - the sky box is upstairs - I can change channel on the sky box but cannot get a picture on the tv in the kitchen - I am using scart into the tv and sky box and the red yellow white adapters into the av sender boxes - any thoughts?
SOURCE: i need a service code for a logik tv L32HE23
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
SOURCE: how do i enter the service mode on my logik L32HE23 tv?
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
