You will have to order the diagram from the following link.click the link directlyhttp://www.vacuum-depot.com/eureka_vacuum_repair_parts.asp ---------- thanks.keep updated.
What colors are the wires?
Http://thevacuumsite.net/s/eureka_vacuum_schematic
Look at this site it will give you all the drawings you need
Take the black lead of the power cord to one on-off switch lug, then take wire off other switch lug to one motor connection terminal, brilg other motor terminal wire back to other wire on the line cord.simply a series power circuit
You can get what you need at www.vacuums24x7.com/Eureka-Parts
They are authorized Eureka dealer for parts. They have parts and service.
Thanks, but this Motor has three connections and a thermal fuse. Need more info before I can start hooking wires up. Anybody have a diagram of this?
erick0651
Thanks dmftrucker, but this Motor has three available connections on the housing. Need a wiring diagram or more info before I can start hooking up the wires.
erick0651
Thanks dmftrucker, but this Motor has three available connections on the housing. Two are the brushes, don't know what the third one is for. Also have a thermistor or what? Need a wiring diagram or more info before I can start to hook the wires up.
Motor Wiring Schematic for Eureka 4388 Bagless Vacuum is what I'm needing, haven't found it yet.
Still need more info Black is on foot switch White is loose. Thermal switch of some kind is Black in and Yellow out and is loose. Motor has four connections two Field and two Brush. See Image:
People keep sending me to parts sources. I need to know the connection sequence for the motor wiring.
