Question about Eureka Whirlwind 4388 Bagless Upright Cyclonic Vacuum
Need to order a roller brush for Eureka model 4388
Posted by deejayh on
TotalVac
  • 52 Answers
The vacuum models is a Eureka Victory Whirlwind. Here is a link to the brush roll
http://www.totalvac.com/60844-5.html
Posted on Jun 12, 2010
Carl
    President:
  • 1,124 Answers
How to replace eureka model 4388 belt
Hi, it's Allie from Crucial Vacuum!
Changing the belts in your unit is easier than you think. To do so, you will need a phillips head screwdriver. First, start by unplugging your vacuum as a safety measurement. Using the lever in the bottom of your unit, recline your upright until it lays flat. Unscrew all 4 screws from the floor base cover and remove the cover to expose the roller brush and belts of your unit.
Carefully, remove the roller brush by using your hands, make sure to hold on to the side of the roller brush that has the belt so it does not pop out and hit you. Once the roller brush is removed, gently take the belt off the metal spool, and replace with the new belt.
We have a very helpful tutorial in our webpage that can assist you in replacing the belts on your unit:
https://www.youtube.com/watch?v=IFcjzuplX_o
You can purchase direct your replacement belts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/eureka-style-u-belt-2pk.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
Aug 19, 2014 | Eureka Whirlwind 4388 Bagless Upright...
What size belt does a eureka whirlwind take
Your Eureka Whirlwind 4388 takes Eureka Style "U" Belts, Part number 54312.
Here's a direct link back to that belt on our website if you need to purchase one:
http://www.govacuum.com/1541.html
Feel free to ask further questions by using the comment field on the repair page.
Thanks,
Chris J.
GoVacuum.com
Apr 26, 2010 | Eureka Whirlwind 4388 Bagless Upright...
What belt do I purchase for eureka whirlwind litespeed
If you have the exact model Eureka that this repair was listed under, model 4388 then please find a link to the belt you need below. If you'd like to verify the model number, please check the back or the bottom of the vacuum for a sticker that also will contain the serial number, and look for the word Model Number. If you don't have the 4388, please just add a comment with the model you have and I'll be more then happy to verify these two models take the same belt, or give you a link to the belt that goes to your model if they are different.
Here's a link to the exact belt called for on the model 4388:
Eureka Extended Life Style U Belt, Part 61120
Here's step by step instructions on how to replace the belt:
How To Replace Brush Roll Belt
NOTE: Turn off the switch and unplug the electrical cord
before replacing belt. Belt pulleys can become
hot during normal use. To prevent injury, avoid
touching the motor pulley when checking the belt.
1. Lower handle to floor to change belt.
2. Loosen, but do not remove, two screws to release hood.
Lift hood to remove.
3. Lift left end of brush roll.
4. Remove and discard belt.
5. Place new belt around motor pulley.
6. Place belt around brush roll pulley.
7. Align left end cap with square in base. Push
end cap into place; see left side view.
8. Pull right side of brush roll to stretch belt.
Secure right end cap into base.
9. Rotate brush roll to seat belt.
10. Replace the hood. Make sure hood front is
behind furniture guard. Hood should seat
onto self-locating screw tabs.
11. Tighten screws.
I hope this information was helpful to you in changing the belt. If you have any questions about how to change this belt, please just add a comment here on the repair page of Fixya, and I'll be happy to answer any follow up questions you might have. If you found this helpful, please be so kind and rate my repair helpful and / or leave feedback for me.
Thanks so much,
Chris Jones
GoVacuum.com
Apr 21, 2010 | Eureka Whirlwind 4388 Bagless Upright...
Change the belt
Hi There,
Here's how you can replace the belt on your Eureka SmartVac 4870. I have taken pictures of the repair to help you better with this.
Here's what you'll need in order to complete this repair:
- Eureka Style R Extended Life Replacement Belt, Part 61110
- Eureka SmartVac Model 4870 Roller Brush Assembly, Part 61520 (Only if the brush no longer spins, or the brushes are worn out)
- Phillips head screw driver
Step 1. Turn the vacuum upside down so that the brush roller is facing upwards. Unscrew the three screws that I've highlighted in red.
Step 2. Remove the bottom plate after unscrew the three red highlighted screws. Once you remove the bottom plate, you'll have full access to the roller brush and belt area. Remove the roller brush by pulling straight up on the roller brush itself. Discard old belt, and test roller brush to ensure that it spins freely by holding the very end of each side, also called the bearing caps with just your finger tips. Try spinning the brush with your thumbs. The brush should spin several times around with each spin. If you notice the brush doesn't spin at all, or if you feel some resistance when you spin the brush, this means that your bearings are either gone, or will be soon. It may be time to consider a new roller brush at this time.
Step 3. Remove the new Eureka Style R belt from the packaging, and wrap one end around the the metal pin, on the opposite side of the roller brush. This pin is actually the motor shaft that spins the belt, which spins the brush.
Step 4. Wrap the other end of the belt through the side of the roller brush that has the pulley, and use the roller brush to stretch the brush roll back into the agitator housing. Make sure the end caps fit in the housing correctly by making sure there are no gaps between the roller brush housing and the end caps of the roller brush.
Step 5. After reinstalling the roller brush back into the housing with the belt attached, pull the belt forwards towards the brush. The brush should spin when you do this. Make sure that the belt is not pinched underneath of the roller brush or this will cause the belt to break immediately when you turn the vacuum back on.
Step 6. Reinstall the bottom plate, making sure that the little notches on the front end of the bottom plate tucked underneath of the reverse notches on the bottom housing of the vacuum cleaner. Tighten all 3 screws back into the bottom plate. Make sure the vacuum is set to carpet mode, and turn the vacuum on.
If you have any questions about this repair, or if you notice that the roller brush stops when the brushes hit the carpeting, please just use the clarification request form here on the Fixya repair page. I will then be happy to walk you through a little more advanced repair of replacing the clutch in the Eureka SmartVac that controls the rug/floor switch. Most of the time though the belt will be all the vacuum needs.
I hope that this was helpful information to you. If this helped you, please be so kind and rate the repair as helpful by clicking on the thumbs up icons in the top corner of this repair.
Thank you very much,
Chris J.
GoVacuum
Apr 04, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
4870 roller part number
I know the belt number
Eureka Part Number: 61110B (Replaces 61110, 61110A)
And the roller i think: Genuine Eureka Brush roller part number 61250-3 for Eureka The Boss/Smart vac/smartvac ultra 4800 series vacuums including models 4870 and 4880
Hope this helps you.
Jan 03, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
The dirt cup clip broke and can't find the part!! Eureka whirlwind lite model#4388
I am assuming that you're looking for the handle at the front of the dirt cup... Part # 28131-288N, it has been replaced by part # 74985 Dirt cup grip assembly. If you call Eureka Customer Support at 1-800-282-2886 they will be able to find you a local dealer.
Apr 02, 2009 | Eureka Whirlwind 4388 Bagless Upright...
New brushroll for eureka smartvac 4870; bristles too long to turn
HI Don't forget that you have a height adjustment control so its better to put it in the highest position - if this is not allowing the roller brush to move properly on the carpet then switch the vacuum off, and lightly trim with scissors on the brush lines. Avoid cutting everything down though - a slight trim should improve things. Generally though when brushes appear too long its usually because the height adjustment dial hasn't been set upwards.
Mar 27, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka the boss 5893A brush roller will not work
is there anything jammed underneath.can you turn the brush roller by hand.if not then take it back where you bought it.sounds like you have a defective brush roller
Jan 11, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Location of belt
There are two Phillips head screws on the cover over the power head. This is the cover that fits around the carpet height adjustment knob. You will notice there are four oval shaped holes on each side of the cover and the crews are in the ones closest to the vacuum handle. The screws are black and may be dust covered and therefore hard to see, but this is all that holds the cover on. When you take these out the cover will lift easily off. Once you do this the motor, belt, and brush assembly are accessible. I purchased a bag of two belts at the local ACE hardware. I recommend cleaning the brush while it is out. Also be sure the bearings on each end of the brush assembly turn freely as hair can work into these and cause them to bind. I hope this helps. [email protected]
Jan 10, 2009 | Eureka Whirlwind 4388 Bagless Upright...
Eureka Whirlwind 4388 Bagless Upright Cyclonic Vacuum Logo
288 people viewed this question
Top Eureka Vacuums Experts
Muntejaya Ginting
Muntejaya Ginting
Sheldon Dedek
Mike
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
