Electrolux AEQ8700F Electric Dryer
Problem for Electrolux AEQ8700F Electric Dryer
The dryer won't heat up?
By yankee1961 on Sep 26, 2009
Solution #1
posted on Sep 26, 2009
Not Rated)
drallim
Rank: Guru  Washers & Dryers  Expert
Rating: 87%, 758 votes
Check the dryer dual breakers in your house electrical panel--push off, then on. Try the dryer again. If still no heat, measure the voltage at the dryer socket with a voltmeter across the two slanted slots. It should read ~220 volts AC if correct. If zero, one of the breakers is bad or there is a loose wire between the breaker and the dryer socket. If you read the required voltage, then the problem is within the dryer--likely the heating element. The drum must be removed to access the element.
Was this helpful?
Yes
No
Popular Solutions for Electrolux AEQ8700F Electric
Questions and Unsolved Problems for Electrolux AEQ8700F Electric
Do you recommend Electrolux AEQ8700F Electric Dryer?
Answer
Answer
When the dryer is on the Auto "Optimal dry" setting it never shuts off, even running for 6... (More)
Answer
dryer has power but does not work
Answer
this dryer is less than 2 years old. the clothes will not dry. the error "ad" flashing on...
Answer
Keeps blinking 88888's and won't cancel out. Won't start
Answer
new dryer blinks 888888 and won't cancel. Won't start
Describe your Dryers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dryer Experts
Top Washer & Dryer Repairmen
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
