Photography Logo
N
Narendra Nath Pandey Posted on Oct 19, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have sylvania 10" photo frame SDPF 1089 . How to transfer photos from PC or from pen-drive to photo frame internal memory . Narendra Pandey
Tony Parsons
Level 3:
  • Photography Master 6,405 Answers
  • Posted on Oct 19, 2019
Tony Parsons
Photography Master
Level 3:
Answers
6405
Questions
Helped
1652405
Points
20272
This information will be in the manual which accompanied the photo-frame upon purchase.
5 Related Answers
Anonymous
  • 248 Answers
  • Posted on Jun 20, 2008
SOURCE: Philips digital photo frame 7FFI series
Here`s a tip i found for you...
1. Connect the frame to your PC using the supplied USB connector. Navigate to the \DCIM\100Frame directory and delete all the Phillips advertising pictures there.
2. Create a directory on your PC and put copies of all the pictures you want to display there.
3. Download the free picture resizer utility from Microsoft at:
http://www.microsoft.com/windowsxp/downloads/powertoys/xppowertoys.mspx
(Look for Image Resizer in the right column). After installing it, "Select All" pictures in the directory you created, then right click and select "Resize Pictures" from the context menu. Choose the 640x400 radio button. Sort by size and copy all the small ones into the "\DCIM\100Frame" directory on the frame drive (Called Removable Disk on my PC).
Anonymous
  • Posted on Dec 24, 2008
SOURCE: internal memory photos download to sd card
1. Ensure memory card is inside camera.
1. Turn on camera.
2. Press Review button on back of camera
3. Then Press Menu Button on back of camera
4. Select "Image Storage" option (by depressing the joystick on RHS of back of camera).
5. Select "Internal Memory" option (by depressing the joystick on RHS).
6. Select "Continue"
7. Press Menu button.
8. Press "Review" button
9. Press "Review" button again.
10. Press "Menu" button.
11. Scroll down to "Copy" and select this option by depressing the joystick.
12. Scroll down to "All", then select by depressing the joystick.
13. Contents should now copy over from internal memory to SD card.
14. Don't forget to reselect Auto detection of SD card afterward. This is done by turning camera off then back on again. Press "Review". Press "Menu". Select "Image Storage". Select "Auto". Select "Continue".
Anonymous
  • 18 Answers
  • Posted on Dec 27, 2008
SOURCE: transferring photos from computer to picture frame
3 Doing more with your frame
Copying between your frame and computer Copy pictures, videos, and music via the included USB cable. For wireless copying (EX models only), see Picture transfer software—copying wirelessly.
Connecting to your computer autourg00722003id1479308.jpg Copying pictures to/from your computer Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools. See info.jpg for applicable file formats.
spacer.gif spacer.gif spacer.gif spacer.gif 1. Connect the USB cable from the frame to your computer (Connecting to your computer).
autourg00722003id1967406.jpg 2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, USB devices.
3. Navigate to the pictures you want to copy. Then drag and drop them to the new location.
4. Unplug the USB cable to view your copied pictures.
See your computer documentation for more information on copying files.
Copying pictures from EasyShare software It's easy to copy pictures/videos from My Collection to your frame.
  1. Install EasyShare software from the CD included with your frame (Installing the software).
  2. Connect the USB cable (Connecting to your computer).
  3. On your computer, open EasyShare software. Select the pictures in My Collection and drag them into the Picture tray.
  4. In the menu bar, select File ® Copy to.
  5. Select the frame source to which you are copying.
  6. Select Best For Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
  7. Click Copy. Pictures are copied to your frame.
  8. Unplug the USB cable and press autourg00722003id1974433.jpg to navigate to your copied pictures.
Anonymous
  • Posted on Feb 01, 2009
SOURCE: Saving photos to internal memory on ultech digital photo frame
go to http://camera.manualsonline.com/ex/thread/view/idthread/1339017
lots of good instructions, I got mine working already
zohail
Shoaib Rais
  • 1223 Answers
  • Posted on Mar 07, 2009
SOURCE: transfer photos from pc to memory stick
simple way
u need a card reader installed in the pc/laptop then u can easily insert ur stick if its supported and it will show up in removable device my computer list of devices
workable way if u dont have card reader
other way if u have usb cable with ur pda then simply connect it to ur pc on usb port and in the menu select mass storage mode from pda i dont know which pda u are using u dont need any drivers for that its just plug and play in Win XP and Vista it will also come up like rem drive in my computer
if u want any thing else or u can tell me the exact model of ur pda to get more specific help
pls rate me FIXYA for this help
1helpful
How do you copy pictures from a Sylvania Model SDPF 1089 digital picture frame onto a portable storage device so that we can get the pictures printed? Thank You. Bill
You will not be able to do this - the software in the frame does not permit this action. You will have to use the original images.
Sep 25, 2019 • Photography
Sylvania sdpf1089 doesn't recognize any of my photo inputs on USB or micro SD. Is there a format problem?
If the manufacturer or Manualslib.com dont have specs / manual with image format compatibilty, try saving a test photo as various formats and dimensions, ratios and DPI.
From personal experience, I found that Corel's Photo Studio converts single images quite nicely, whereas XNView does bulk conversions in one go.
If your photos aren't JPG, try this format as it seems to be universal across many devices.
No idea what Sylvania sdpf 1089 uses, tho....
Sylvania sdpf 1089
Rotate images correctly. : NIX Digital
https://support.nixplay.com/entries/66055804-Rotate-images-correctly-
Apr 7, 2015 - images that are uploaded to the frame should always display .... I amdisplaying images from my SD card. ... of photos coming from USB or SD will stillneed to be rotated if there is an exif ... "save as " from the account they are the correct orientation on my computer. .... Everything worked correctly after that.
Photo Rotation Problem - Community@Insignia
community.insigniaproducts.com/t5/...Photo.../Photo-Rotation.../td.../508...
Dec 28, 2009 - I have a few pictures that I already rotated correctly on my computer. Even so, they display incorrectly on the digital frame (buildings and people. ... When I bring the picture back to the picture frame, the rotation is still .... Just extra info - If I put the picture directly into Internal Memory .... Save as 24-bit Bitmap.
Galaxy S3: Photos are always being rotated! Why! - Android Forums ...
forums.androidcentral.com > ... > Samsung Galaxy S3
6helpful
How do i download pictures to tablet
Pandigital photo frames are an ideal way to display your collection of digital photos. You can view photos with or without a computer using just a memory card, but it's always a good idea to transfer the photos you'll want to view frequently to the internal memory of your frame. This is also a handy way to back up your favorite images.
  1. Transferring Photos from a Memory Card
    • Your digital photo frame's built-in software will recognize six types of memory card: CF I/II, SD, MS Pro, MMC and XD. Locate the slot on the back of the frame (to the left of the stand) that corresponds with your type of memory card. These are labeled as follows: SD/MMC/MSPro/XD, CF I/II, USB and mini USB. Insert your memory card into the appropriate slot, power on your digital frame, and it will automatically begin a slideshow using every available image on your memory card. Note that only JPEG formats under 16 megapixels are compatible.
    Transferring Photos from a PC
    • Use the USB cable that came with your frame. Connect the mini USB end to the mini USB port on the back of your frame; connect the large USB end to your computer's USB port. Double-click the "My Computer" icon on your desktop or in your Windows "Start" menu. You'll see that your computer has automatically assigned a drive to your digital frame---look for a device called "Removable Disk" followed by a letter (Removable Disk E:, for example). This is the folder that represents the internal memory of your digital photo frame; you will be dragging your photos into this folder.
      Next, open the folder in which you store your photos ("My Pictures," for example). Select the photos you want to transfer to your frame. Drag them to the drive associated with your digital photo frame---this is the "Removable Disk" drive you located within the "My Computer" folder. Every photo you selected will then be copied onto your digital frame.
      After the files are copied, disconnect your digital frame properly. If you don't, your frame's internal memory could be damaged. Look for the system tray in your desktop's lower right-hand corner. Left-click the icon that shows a gray box with a green arrow on top of it. Select "Safely Disconnect Hardware." A dialog box will appear, asking you to select the device to disconnect. Select the digital frame and click "OK." When the dialog box appears, click "Close." You'll see a message in the lower right hand portion of your desktop telling you it's safe to disconnect your frame.
    Copying Photos to Your Frame's Internal Memory
    • You can use your frame's remote control to copy photos from your memory card or computer to the photo frame's internal memory. Connect your photo source (computer or memory card) and have your frame's remote control handy. Access the "Home" screen on your frame using the "Home" button on your remote control or by pressing the "Home" button on top of the frame. Next, choose "Photos" and press "Enter." You'll see all your photos in thumbnail form. Scroll through them with the up and down arrows. Press the "+" key to mark photos you want to copy (use "-" to de-select a photo). When you've selected all the photos you want to copy, press "Set Up," then "Copy Photo," "Enter," "Selected" and "Enter." A dialog box will ask you to confirm your selection; with the cursor on "Yes," press "Enter." The photos you selected will be copied to the frame's internal memory.
I cant transfer pictures from my PC to a Digital Frame
either transfer to a usb pen or a standard digital card and then insert in photo frame good luck
Virus on photo frame
I suggest you plug it in on your computer and use the existing anti virus program on your computer to clean it.
2helpful
Just bought a sunpak 7" photo frame. Trying to put pictures from flash drive onto the memory on frame. How do i do it?
I have found that when you have the source of the photo files connected to the picture frame and are viewing from the menu it says "USB" Select the photos you what to paste by following the instructions and then change the "Device" to "favorites" and the paste by pressing the "enter" button.You can only paste about 10 files or photos at a time...so if you have allot it take a while. hope this helps
Digital photo frame
hi there
you can do that by inserting our digital photo frame to your computer via usb and as soon as yor pc recognizes the photo frame, you can try and sending your photo towards it. you digital photo frame has internal memory so you might wana transfer those pics there. running from picasa however, you need to explore using picasa and as soon as picasa recognises the digital photo frmae, you can transfer now.
hope this helps..
Feb 07, 2008 • Cameras
Top Photography Experts
Tony Parsons
Tony Parsons
ADMIN Andrew
ADMIN Andrew
Are you a Photography Expert? Answer questions, earn points and help others
