Hitachi 51S500 51" Rear Projection HDTV-Ready Television Logo
Posted on Sep 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Hitachi 51S500 is showing a black screen
My Hitachi 51S500 is showing a black screen with the word locked on it. When I turn on the TV, majic focus flashes thru all the colors, then a grid square of small white boxes appear across the screen. Now I am getting no sound or picture just a black screen with locked on it. Please help. Thanks
Anonymous
Level 3:
  • Master 647 Answers
  • Posted on Sep 19, 2009
Anonymous
Master
Level 3:
Answers
647
Questions
Helped
150016
Points
2098
Did you unplug the set from the wall and wait 5 min. replug and try. Cusult your owner manual regarding parental Locks?
Hitachi 51s500 screen is flashing, but no real picture or sound, where is the master reset button?
this set has no reset button at all. If the screen is flashing is it red,green, blue, 3d or what? This may be a clue to what is wrong.
HI, I have an old June 2003 Hitachi 51S500 , that i have been trying to unlock for a friend of mine , She said it just started showing one morning . am not sure what kind of lock or what it is All it...
hi this is a problem with the main board clearly
the fact that it is not allowing a code and also the fact that it is asking for a code that was never put in on the first place this shows that the main board has a fault and is causing the controll unit to send out a locked message that cant be unlocked it is not possible
solution:new main board
Connect hp laptop to tv to watch Netflix downloaded movies
how do i hook up my hitachi tv to my hp laptop to get netflix?
What is the replacement lamp part # for a Hitachi Rear Projection 51S500
You have 3 Tubes RED/GREEN/BLUE you do not have a Lamp your TV is projection not DLP Go to Encompass Electronics.com 1-800-638-3328 they have a list of all parts to your TV.
1helpful
2answers
Hitachi 51S500 51 in.
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Hitachi 51S500
check out ctechnicians.com and ask if its the pink screen?
Center of my T.V. is black.
Turn off all closed captioning in menu and change it from text to caption.
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
