is there a remote code to have the hitachi 51s500 remote control my sony slv-d370p dvd/vcr combo?...
(More)
is there a remote code to have the hitachi 51s500 remote control my sony slv-d370p dvd/vcr combo? none of the sony codes in the hitachi user guide work...
I have to unplug AV cable from the back of my ps3 whenever I want to watch tv on the input 1...
(More)
I have to unplug AV cable from the back of my ps3 whenever I want to watch tv on the input 1 channel. If I don't the picture will be very distorted. The AV cable is inserted in the input 2 port and my cable HD cables are inserted in the input 1 port.
My Hitachi 51S500 is showing a black screen with the word locked on it. When I turn on the TV, majic...
(More)
My Hitachi 51S500 is showing a black screen with the word locked on it. When I turn on the TV, majic focus flashes thru all the colors, then a grid square of small white boxes appear across the screen. Now I am getting no sound or picture just a black screen with locked on it. Please help. Thanks
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
written by Ecollier2012
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Before you order new convergence chips to try to fix the double vision or 3D look on your tv check the solder points for the chips. If you are able...
written by misenhei
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
