Televison & Video Logo
Posted on Sep 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can no longer get channel 8 on my tv. It's a
I can no longer get channel 8 on my tv. It's a new set and new antenna. I have scanned all the channels several times and still nothing.
Anonymous
Level 2:
  • Expert 93 Answers
  • Posted on Sep 17, 2009
Anonymous
Expert
Level 2:
Answers
93
Questions
0
Helped
24928
Points
185
Channel 8 is an analog channel . See if you have a diditial tuner , if so ,do a digital scan and that get you a version (8.1/8.2,etc) of the channel you are looking for
3answers
System shows I need to scan the tv
Impossible to answer without 'Make and Model', but we can guess.
Scan for what? Scan for new channels?
How to Scan (or Rescan) For Channels on Your TV
How-To Geek https://www.howtogeek.com > how-to-scan-or-rescan-...
Jun 19, 2019 - Find and select the "Channel Scan" option in your TV's menu. This option is sometimes labeled "Rescan," "Tune," or "Auto-tune."
2answers
My Tv no longer registers a signal from the antenna. I can see a picture thruogh my smart DVR and Chromecast but no pic with TV antenna. I bought a new antenna, still no signal.
Is the TV set to air or cable? It has to be set to air/antenna and a channel search has to be done first before a picture will show.
My Sony KDL-52xbr4 was working fine until I did a re-scan of the digital channels. After the re-scan the TV finds no digital channels. All other TVs hooked to the same antenna work fine. The sony scans up...
Hi check to make sure the antenna is connected correctly. try tunning the channels manually and if they come up you can save them one at a time. Also try moving the antenna to a different location. make sure the TV is set to scan on the same input that you are connecting the antenna. If all that fails ou might have a defective tuner board.
You can get parts for this tv at www.interliquidparts.com
1helpful
Whilst watching digital channel, tv suddenly said channel not tuned. Same problem with all channels. Now comes up channels not stored, and when trying auto start up, says no channeels found.
Ur tv,u are using and getting a over the AIR free broadcating tv channels signal wright?Ur antenna are using,have problems might not work anymore in ur area.Tries manual channels scanning ur tv should get it back or buy a better antenna deign like a Digital antenna design for a hook it up for a better signal prob and longer signal ranges tries scanning for Free over the AIR channels again should solved this problems.
4helpful
2answers
Why won't my new Vizio DTV work on an antenna without the digital box?
Do you have the antenna aimed correctly and the correct antenna for the distance between your location and the stations? Check antennaweb.org and tvfool.com for the directions to the stations you should be able to receive. Antennaweb assumes an external antenna and is very conservative in the station list. TVfool gives the stations you should get with various different types of antennas. Tall trees and buildings will block signal strength so consider the environment around you.
With digital signals, if you do not have enough signal strength for a given tuner, the channel will not come in. An amplifier may help you get the signal, particularly if the signal is shared to several devices. Failure of an amplifier or lightning surge protection can stop the signal from reaching the TV. A surge through the antenna can damage the tuner.
A damaged cable can also be a source of a problem. Check the outside portion of the wire as well as the interior wires. Replace any that have damaged insulation or ends.
For this TV, if you have done a channel scan with the TV set to the Input TV/DTV, and the Signal Source set to Antenna. Turn the antenna and then set the Additional Scan to On. (Menu > TV > Channels > Additional Scan.) Then do another channel scan.
If you need a copy of the manual, see: http://www.vizio.com/m220va.html#support .
1helpful
No digital channels
  1. Cable company sending something through the line. Also th insigna has a different tuner. Also can the insignia find the digital channels using an antenna?
1helpful
Where are my antenna channels ???
Please try Auto Programming the TV.
Please refer to the page number 37 in the manual to get information about Auto Programming the TV.
Select the Auto Program option under the ANALOG SETUP SETTINGS in the Menu of the TV to Auto Program the TV which should resolve the issue.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
