If it is the line you may need to replace the whole line, if you have the right tools to splice a new piece in then you may do that. you will need a flaring tool that will double flare the line. You may even be able to purchase the length you need with flares and nuts already installed, from your local auto parts store for a few bucks.
You can splice a small piece in, assuming there is room and the surrounding hose is solid.
Make sure you use the correct flare for high pressure lines. Usually a double flare.
You can replace only the short section if you like using compression connector and they are easy to find them at the hardware store,or do the whole line since they are no really expensive,the whole deal would cost aroun 20 or 25 bucks (parts only)
