Konica Minolta Bizhub C 6501 Color Copier,ic 408,bizhub 6500,only 442,000 Copies Logo
s
sina mosavat Posted on Oct 02, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
WHATS MEANING OF ERROR C2831 IN KONIKA MINOLTA 6501
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Feb 22, 2020
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1913983
Points
11960
Clean the sensor behind the yellow drum or replace it.
5 Related Answers
mochicas
  • 26 Answers
  • Posted on Feb 21, 2009
SOURCE: Driver utility of Konika Minolta Bizhub 162
Use the bizhub 180 same family
driver
Anonymous
  • 15 Answers
  • Posted on Jun 17, 2009
SOURCE: konica minolta bizhup 6501 error c-2452
Something with your developer causing not enough toner. Maybe an auger issue in the developer or in the toner feed itself?
Anonymous
  • 44 Answers
  • Posted on Dec 07, 2009
SOURCE: error code c-2833
CAUSE: LD Power becomes saturated when performing Auto Gamma adjustment in a low humidity condition.
SOLUTION: Perform the following adjustment:
1. [Utility].
2. [Machine Admin. Setting].
3. [System Setting].
4. [Expert Adjustment].
5. [Process Adjustment].
6. [Toner Quantity / Exposure].
7. Select the proper Exposure Adjustment [Yellow, Magenta, Cyan, or Black] by using the Next/Previous button.
8. Select Standard then select [-2] under Exposure.
9. Press OK.
Notes:
a. If the problem persists, replace the problem color drum since the cause of the SC is the combination of drum characteristic and humidity.
b. The following codes = colors: C-2831 = Yellow; C-2832 = Magenta; C-2833 = Cyan; C-2834 = Black.
pineworks
Clive
  • 4362 Answers
  • Posted on Apr 28, 2010
SOURCE: konika minolta bizhub 350 Error c3451
Hi there.
Try this It could do the trick for you.
The error code c3451 refers to a copier warm up error; the machine had not reached the correct temp within a specific time.
I bet it happened when you first switched on one morning.
Easy to reset and fault usually goes away.
To Reset switch machine off using the switch inside the front door, not the one on the control panel.
Whilst holding the UTILITY key down on the control panel switch the machine back on keeping the UTILITY key held down. Eventually a Trouble reset key will be displayed in the LCD screen, touch this, OK will be displayed then power the machine off and then back on.
This will reset the error code, if the code reoccurs then there will be a problem with the fuser unit in the machine, and this will requir
e replacing.
Hope it did work for you.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Anonymous
  • 60 Answers
  • Posted on Feb 22, 2011
SOURCE: HOW DO I SOLVE ERROR CODE C3451 IN KONIKA MINOLTA
You will need to replace the thermostat and the best solution is to ask a technician to do that.
Error code C-C134 - konica minolta C6501 Pro - Konica Minolta Office Equipment & Supplies
Has the IPB been replaced? It may be the wrong one.
A03U H020* is for 6500/5500
A03U H0200* is for 6501/5501
J1601 error code in 6501 printer
check tray 4 rollers sensors and paper.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica minolta 6501 error code c-c101
had a circuit board replaced recently??? if so check each and ever connection, pull each connection and reseat each connection one at a time while each connector is removed check all pins for a bent pin. Or replace the Print control board, Interface control board, image control board, and the overall control board, $$$$$$$$$$$$$$$$$$$$$$$$$ more then what you paid for the machine!!!! Then you will still have to remove each connection and reseat them and look for bent pins!!!!!
C2831
at model machine
1helpful
Konika minolta di1611 error xodes
You must be change the developer and the opc drum and drum cleaning blade.
Error code c2863
Hi, i have a konica minolta c6500, and i have a problem with error code c-6500. What happen?
1helpful
3answers
Konica minolta bizhup 6501 error c-2452
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
