"safe mode" is generally used to correct wrong drivers etc. that you installed.first thing i would do would be to install "Free Windows Registry Scan".after i ran it on mine and corrected the errors it found;all 3 of my PC's ran better with no error messages.
search for it.
While an Operating System is in the Safe Mode, it will have reduced functionality, but it is easier to isolate problems because many non-core components are disabled.
Restart the Computer and press the F8 key at the Startup to start the Computer in the Safe Mode.
Try performing the System Restore in the Safe Mode.
Click on Start -> All Programs -> Accessories -> System Tools -> System Restore.
Then restore the Computer when it was working normally.
NOTE: The System Restore procedure will restore the Registry and other settings back to the date and time selected. No data will be lost. Saved documents and e-mail will not be affected by performing a System Restore. Any Hardware or Software that has been installed after the date of the restore point will need to be reinstalled.
Good Luck!!!!!!!!!!!!!!!!!!!1
Safe mode will not delete any files or documents saved on the system.
Safe mode only loads basic drivers that the system needs to operate, it is used for resolving problems with the PC. The audio, graphics and network (internet connection) are all disabled when you boot into safe mode.
Don't worry, safe mode is exactly as its name describes itself.
If you need anymore advice please post back.
Regards.
What type of errors are you getting? Is Windows crashing or are you getting other errors? Have you run a full virus and malware scan? It's not a good idea to continue using it without backing up your precious data (copy to a CD or other removable media) as you may well lose it. It's unlikely you will do any physical damage to your computer but reliability will be an issue.
