Easy fix. I found elsewhere on this site that the solution is to RESET the printer via the following instructions from HP...
1) Unplug Printer
2) Simultaneously press and hold the HELP & OK buttons
3) Re-plug in printer, while still holding the two buttons.
That's it ! You are reset. It will take a little time for the printer to re-configure, but you'll be printing in 5 or so minutes.
Thank you so much for this tip. I've tried everything without any luck. Today I found this tip and after being without a printer for one week it finally works again. Thank you again.
Thank you! This worked for me, too. Hold OK and Help while re-plugging. press power button while still holding the buttons.
This is a critical issue my friend.
An ink system failure with the error code that starts with 0xc18a means there is a serious hardware problem on the printer.
The only option that you have is to get the printer replaced.
If your printer is still under warranty(i.e if its still not an year old) you can get a free replacement from HP.
wherein they will send you a new printer absolutely FREE OF COST
if its not in warranty then you can opt for the UPGRADE option that HP has.
You can send them this faulty printer and get a LATEST PRINTER at a huge discount..
here's the number to call
1800-474-6836
Testimonial: "Very helpful! I am disappointed that this printer is dead/broken because it is barely 1.5 years old. "
SOURCE: Ink system failure the ink system has failed and
Go to An '0x ...' Error Message Displays on the Front Panel When Printing HP Photosmart C5380 All-in-One Printer - HP Customer Care (United States - English)
If you need more help post back!
Thumbs and testimonial are welcome!
error: Oxc19a0035 ink system failure
