fuses make very little sound when they blow so a loud sound in a microwave is an expensive sound
best take it in for a proper diagnosis and quote as many loud sound repairs cost more to fix than a new unit
Aug 12, 2011 - 10 posts - 2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
follow this steps and use the VOM , and fix it. God bless you
MagnetronIf your
microwave is emanating high pitched or growling noises during operation,
the magnetron could be going bad. Normally a nearly silent part, the
magnetron uses high voltage and induces the frequency required to cook
food. Although normally not a safety hazard to operate, this is a sign
that the magnetron is failing and will need to be replaced as soon as
possible.
Exhaust fan motorIf
your microwave is making a very loud humming noise during operation, it
could possibly be the exhaust fan motor. If defective the part will need
to be replaced to silence the appliance once more.
Stirrer motorAnother
leading cause of a noisy microwave is an expired stirrer motor. With use
this part becomes worn and makes a loud grinding noise, which is
usually a leading indicator that the part needs to be replaced. The
stirrer is a metal blade that is slowly turned by the motor. This action
disperses the microwave energy in a random pattern, which heats the
food evenly. If the stirrer motor is determined to be nearing
expiration, it should be replaced to halt the grinding noise.
Turntable motorA very
common cause for a noisy microwave is a worn out turntable motor. This
is a relatively easy repair and will put an end to the noise once
replaced.
this is due to the magnitron tube is arching and there is possibly grease or dirt around it .You may need to replace the microwave. The drive for this model may be belt driven and the belt is worn and slipping. Repairs for this is usually a lot more than a new microwave.
The turntable system
consists of the motor, the coupler, the turntable support with rollers,
and the tray.
You can see and hear a video of how a turntable motor should
sound when you rotate it by hand.
If
yours is not set to be off via the control panel, and it won't rotate
or it sounds like it's grinding, etc., you may have a bad motor or
plastic coupler.
To
replace either, you need to unplug power, then remove the bottom cover
of the oven.
You can order
parts for this brand from Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
Most likely a shorted capacitor is causing the fuse to blow. Easy and cheap to fix. Check with www.martinmicrowave.com or call toll free 1-877-894-0035 for parts info
