This Microwave is installed in an RV. When it is plugged in it squeaks like something is moving. Upon removal of the top cove there is a door on both sides of the microwave that is constantly rotating. How do I fix this.
Follow this steps and use the VOM , and fix it. God bless you
SOURCE: microwave buttons not responding - microwave running constantly with door shut
OK, you will need to replace the magnetron and the touch pad as well. this will fix this issue.
SOURCE: Microwave Steams Up, Heats Up, and Shuts off!
first of all your mwave needs to be properly ventilated .the problem is your magnetron when heated the thermal cutof switch cutts out power to magnetron.works again when cool.change magnetron
SOURCE: GE Spacemaker XL 1800 - Noise while heating
Maybe you and the person from the post below could get together and help each other? http://www.fixya.com/ThreadView.aspx?prdid=489218&thid=130453
SOURCE: GE over the range microwave making grinding noise
This sounds like the stirrer. If it sticks or stops, the microwaves can damage or destroy it. You may have a bad stirrer or magnetron. There is an important bulletin that covers these problems. To see if yours is covered, see: http://207.234.249.73/mwd/ge_mw_mag_kit_bulletin.pdf If you need more help, please follow-up.
SOURCE: Problem with GE Door Handle
You can find helpful exploded view diagrams and by entering your model number here: http://tinyurl.com/gv383
The noise begins when the microwave is plugged in. It is not cooking, it is just plugged into the wall.
