This beeps occur when some parts inside the CPU are not connected properly. 11 Beeps is VGA Card not properly connected or bad. Try to use another VGA Card.
And remove any PCI Cards that are connected inside and see to it only VGA Card is in to make sure the beeps or the Computer is going to run normally.
Please rate me.
You will need too look up the error represented by the beep. The beeps maybe long and short mixed. If it is a major brand PC, you need to know the model number. If it is a no name brand/home made, you need to know the bios manufacturer. It is usually AMI, Award, or Pheonix. Then you can google "bios post error code".
