You cannot change the aspect ratio. When a program is transmitted in 408i you will get a small picture in the center of the screen surrounded by black bars. This not the fault of the TV. You can try using the zoom feature, but the picture clarity will suffer.
You need to check the zoom or aspect ratio on your TV remote and or your cable/satellite remote. The zoom or 16:1 aspect ratio often cuts off words if the movie or show is in 4:3 ratio.
CHANGING THE SCREEN ASPECT RATIO: ( From Manual )
The TV can display images in four different modes: Wide, Zoom, Panoramic, and Normal. Each mode displays the picture differently. To change the screen aspect ratio:
1. Press the MENU button on the remote.
2. Use the Arrow buttons to highlight the Wide icon. Press OK.
3. Use the Arrow buttons to highlight your desired screen mode and press OK:
• Normal preserves the content's original aspect ratio. Since the 4:3 aspect ratio is not large enough to fill the TV's screen, black bars are added to the left and right of the display image.
• Wide stretches a 4:3 aspect ratio picture to the edges of the screen. Since the picture is being stretched, the display image may appear distorted. If the program is already formatted for widescreen viewing (1.85:1 or 2.35:1), then black bars will appear on the top and bottom of the display image.
• Zoom expands images with black bars to fit the screen.
• Panoramic expands the display image to fill the screen.
images may appear wider than intended.
If you are watching widescreen (1.85:1 or 2.35:1) content, black bars will still appear on the top and bottom of the display image. This option is only available when the TV is displaying a 480i/480p source.
try to check the aspect ratio and input source to make sure they are correct. for the aspect ratio, make sure it is set either at 16:9 ratio or try the zoom options. if it is set at zoom, you can move the screen left to right or up or down through the zoom settings. make sure you are also using the correct cable. hope this helps
You need to change the aspect ratio of the screen. The cable box remote has an aspect ratio button and the tv remote also has an aspect ratio button or picture size button. You are probably on a zoom aspect since its too big.
it sounds like you have hit the zoom button or your aspect ratio isnt right. the aspect ratio should be set to 16:9 (if there isnt a button for aspect ratio, change it in the menu) and there should be a zoom button on your remote and just keep hitting that and it should return to normal. If neither works, post your tv brand and model and i'll try to find another answer
