The error code 1F on an LG refrigerator indicates a problem with the ice maker fan. The most common cause of this error code is frost or ice buildup around the fan. If you have disconnected the water line to the ice maker, then the most likely cause of the error code is frost or ice buildup.
To fix the error code 1F, you will need to defrost the ice maker fan. This can be done by following these steps:
Unplug the refrigerator or turn off the circuit breaker that powers the refrigerator.
Remove all food and drawers from the freezer compartment.
Open the freezer door and allow the ice to melt.
Once the ice has melted, use a hair dryer or heat gun to melt any remaining frost or ice around the ice maker fan.
Wipe away any moisture with a clean cloth.
Reassemble the freezer compartment and plug in the refrigerator or turn on the circuit breaker.
If the error code 1F persists after defrosting the ice maker fan, then there may be a problem with the ice maker fan motor or the control board. In this case, it is best to contact a qualified technician for assistance.
Here are some tips to prevent the error code 1F from coming back:
Keep the freezer door closed as much as possible to minimize air circulation.
Defrost the refrigerator regularly, even if the ice maker is not in use.
Clean the ice maker coils regularly to prevent frost buildup.
If you live in an area with hard water, consider using a water softener to reduce the amount of minerals in the water that can contribute to frost buildup.
By following these tips, you can help to prevent the error code 1F from coming back and keep your refrigerator ice maker working properly.
if you are talking about the motor in the freezer the ice build up could be causing the fan to beat against the ice... could be a defrost cycle problem,,,, if ice is building up on rear freezer wall you have a defrost cycle problem and the ice is forminf around fan causing fan blades to hit the ice (loud noise)
Typically the freezer fan motor should be replaced, the issue usually lies with the tachometer within the fan motor, the main control board is not sensing the proper speed of the fan motor and therefore can't operate it correctly. In many cases the main board gets replaced too to ensure the most up to date software, as GE has had NUMEROUS software revisions on those main boards over the last 11 years. You would need to capture the complete model number from the appliance it's self in order to see if your main board has had preceding part numbers. Pleazer Appliance...
You need to check the fan motor to make sure no ice buildup caused by leaking door seals or the door left open for a while. This will prevent the fan blade from breaking or damage to the evaporator motor. If you are sure about the model number here is a=> D2766GEB_Repair_Parts_List Either way you will need to unplug the power and remove the rear panel in the back of the freezer section to check for the ice build up or simply the fan motor is loose. Adobe Reader can be found here=> Get Adobe Acrobat Reader If the model number is incorrect then click=> HERE where you can find user manuals and part manuals. Let me know what you find, Thanks Sea Breeze
From what you're describing it sounds like the freezer fan motor is causing the noise you hear. The freezer fan is the only moving part in the freezer section. I recommend replacing the freezer fan motor & fan blade together. If there is ice buildup on the back wall of the freezer then the sound is likely from the fan blade hitting the ice and you will need to defrost the unit.
You might have ice building up around your fan or in the back of the freezer. If that is the case, then you have problems with the defrost circuit (defrost heater, defrost thermostat or defrost timer).
Suggest you open up the back panel of the freezer and see what is going on back there, before you have to replace the fan and motor.
You have to take the food, and then the shelves out and then take the 2-4 screws out of the back panel and remove it. If there is ice buildup then you will need to defrost your freezer and then troubleshoot the defrost circuit to determine what part has failed. The good news is that you will be able to order the parts and wait for them to arrive since you can use your refrigerator for awhile before the ice becomes a problem again.
theres ice in the fan propelar, if you see no ice blocking the propellers its the fan motor itself,if you unplug the fridge and stick something thin between the vents where you feel the air blowing thru and try turning the fan,gently and it spins smooth its the fan motor,if you dont wish to do this turn freezer off,open the door and let it defrost,then plug it in if buzz still there its the fan motor
T
From your description, you have a bad evaporator fan motor. The part number for a replacement motor is #5304445861.This is not a direct replacement but is more reliable.Remove everything in the freezer, take off the back panels and you will see the fan.
If there is a large frost buildup on the coils and the fan is turning you have a defrost problem. If that is the case, please call me at 334-347-0000 and I will walk you through it.
Frost is due to outside air leaking into unit. Check on back wall to see if hole for ice maker fill tube is still plugged. If not and you have no ice maker cover hole with tape. Also look for water or ice build up in bottom of freezer or ref. sections. May have a plugged drain. Let me know what you find.
