Computers & Internet Logo
Posted on Jan 08, 2018
Installation of LG 192WS using VISTA
I just installed an LG 192WS. If it is working, do I need to use the installation disk for anything? How do I know if it is working at its best? How do I change the resolution or check the resolution? I don't know what to do because the new monitor is on.
thanks,
Dolores
5 Related Answers
Anonymous
  • Posted on Sep 10, 2007
SOURCE: al1917w lcd monitor resolution problem
Get a new video card, you dont need the best video card to support 1440*900. It is affordable and the best solution.
Anonymous
  • 4 Answers
SOURCE: keep getting a resolution popup.. 1 or 2 does not disable
you will hAve to format pc
A
Anonymous
  • Posted on Dec 24, 2007
SOURCE: best resolution
letter are not clear
Anonymous
  • 139 Answers
  • Posted on Jan 18, 2008
SOURCE: Installing Lexmark 6100 series all-in-one to new hp computer
There are some compatiblity problems between Vista and your printer. Check this web page to download a driver that may provide limited printing capability for your printer...you'll need to use Windows Scanners and Cameras or Photo Gallery for scanning.
Anonymous
  • 22 Answers
  • Posted on Mar 12, 2008
SOURCE: Samsung Monitor resolution reset to 800x600
i think you have problem with your graphics card. restart your computer and then before starting to windows press F8 to set your settings to safe mood, after booting up to windows restart the system again.if the problem persist reinstall the software drive of your graphics card if you have it.
2answers
Problem installing Vista SP1 on Asus G2s
If you tried to install Vista on the Primary drive and formatted the primary HDD your Factory Recovery Partition , most likely has been written over, it's gone. Choose one or the other , Vista or Win 7, start from the beginning, install a clean Vista load, formatting in the installation procedure, form a Vista Installation DVD, follow instructions, boot up, do ALL the Vista Updates, it will take hours of updates, rebooting, updates, rebooting. You will get to the Service Pack's 1 and 2, in 24 hours or so. Put on a pot of coffee and be patience. If you prefer Windows 7 use the same procedure.
3answers
I need to wipe my acer aspire pc with vista. Do I need a recovery disc I do not remember it coming with one?
You can do it without disk to but for it should be hiddden partition is installled when your vista is load first time.For that
There is one option in bios D2d enable it .then save settings.
For enter bios when you power up the computer press F1 or F2 or "del" key then go to main menu find D2d
then enable then save and exit.
Then when it restart press ALT +F2
then you see recovery mode follow the procedure and wiped acer.
But if there is not any recoverry then you need recovery disk.
Let me know if you need more assistanse.
Thanks.
2answers
USB drivers
Try downloading the LG Notebook(R400) Intel Chipset Driver from....
http://www.notebook-driver.com/lg/lg-xnote-r400rd400rb400-notebook-drivers-for-windows-vista/
Let me know if this fixes the issue.
Zod
How to upgrade from Vista Basic to Vista Premium.
You need a Vista premium disk to upgrade to Vista premium.
Just instert the Vista premium disk and start the installation.
If installation does not start, you will need to boot from setup CD, sometimes you have to change the bios boot sequence in bios settings, to start the installation from CD.
2answers
Lost instalation disk
The lexmark drivers ( same as the original cd.. but newer ) are available on the lexmark website http://www.lexmark.com
1helpful
2answers
Lexmark x5470
Lexmark does not distribute replacement install disk for all models.
Contact Lexmark here, to see if the disk for your printer is available.
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:some printerdoes not work on Vista, if you do not find any driver download for Vista on your model page, that means your model is not Vista compatible.
1helpful
2answers
Resource cd for aspire 4315 laptop PC
Some Vista driver may work on XP, however, to avoid any risk of getting in troubles with your Windows xp installation, you can download drivers and utilities for XP starting from this page.
Regards
5helpful
2answers
Not possible xp installation
How to Downgrade Vista to XP Downgrading from Windows Vista to Windows XP is almost like installing Windows XP for the first time. You should take all the normal precautions like backing up all your important files and record important passwords in a different place, preferably on a CD. When you downgrade from Windows Vista to XP, note that Windows Vista will be completely removed from your system.
(Note: There is a way to have both Vista and XP in a dual boot configuration, but that's an option for more advanced users. See Dual Booting Vista and XP for more info on that.)
Before you begin the XP installation, make sure that the necessary XP hardware drivers are available, or included on the XP disk provided by your PC vendor. If in doubt, check the vendor's website or poke around with your favorite search engine to see if others have attempted the XP install on the same hardware. You may be able to install XP without all the needed drivers, but some hardware may not work afterwards.
Also, make sure that you have a genuine Windows XP CD before you begin the downgrade. Be sure to read the section earlier in this article to see if you qualify for a low/no cost XP recovery disk from your PC vendor. If not, perhaps you have an XP disc that came with another computer. If you've upgraded an existing computer from XP to Vista, the best choice would be the XP install/recovery disc that came with that computer. One some PC's the vendor doesn't ship a CD, but the recovery CD can be created from disk images on the hard drive. If all else fails, you can always buy a copy of Windows XP on Ebay. Just be sure it's a legal, licensed copy.
Follow these steps to install Windows XP on your Vista machine:
  • Insert your Windows XP install/recovery CD and restart your computer.
  • Install Windows XP normally, providing either the product key that came with the disk, or the one you got from Microsoft customer support. If the installer warns you that another copy of Windows is already installed, don't worry. Remember, this install will wipe out your existing Vista installation.
  • Activate your copy of Windows XP when it prompts you to do so. If you run into the "already activated" problem, you can use the option to activate by phone.
  • If you own Vista Business or Vista Ultimate, explain to the rep that you want to use your Downgrade Rights to install XP Pro.
  • If you own Vista Home Basic/Premium, or you are installing XP Home Edition, don't mention ANYTHING about Vista. Just give the rep your XP product key (not the Vista key), explain that you are installing XP on a new hard drive, and tell them you need to activate.
1helpful
Kg 300 installation
Hi, What operating system do you have? If XP you will need service pack 2. If it is an earlier O/S you will need a driver disk. If it is Vista, then forget it there are very few drivers around for anything on VISTA. Regards mistyman
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
