If your DVD burner is an old one then the Laser could be going out in which it is not powerful enough to burn Discs anymore but it can still read them. Can it read DVDs?
The more advanced the media is the more likely it can't read them in a older Player. DVDs would be hardest to burn or even read.
If this is the case the DVD burner must be replaced. They are cheap and I would recommend newegg.com. A typical DVD burner is $30.
most sony CD and DVD players have a digital signature design to play CDs and DVDs that are original and licensed. some CDs or DVDs dont work since the player does not recognize or scan any digital signature embedded in the CD or a DVD. 2nd, lens problem causes most players not to read CDs nor DVDs. you can try to buy CD or DVD lens cleaners to have your lens cleaned.
you were saying some? and not all the cds and dvds? it may be that those other discs are unreadable anymore caused by scratches, marks, or the like. if other discs can be read then the player is all good. also check what file format you are trying to play. it may also be that the file format you are playing is not compatible with the program you are using to play it with like windows media player, media classic, etc.
It is a DVD ROM drive which stands for DVD Read Only Memory. In other words, this drive is meant to only PLAY DVDs and CDs but NOT save data to them.
To burn CDs you need a CD burner. Burners are of 3 types:
CD writer only burns and reads CDs.
Combo drive reads CDs and DVDs but only burns CDs.
Super drive burns and reads from CDs and DVDs.
As you go higher in functionality, the price also increases. Check your needs before you plan to buy one. Also compare prices of all the drives. Note: burn-able media costs are separate.
I had similar problem on a Toshiba Satellite A30 laptop, I simply had to reconnect DVD drive. It usually loosing it's connection with motherboard and drive is visible in My Computer but it doesn't recognize any discs. If reconnection does not solve your issue you may try to update your DVD firmware and if it won't help replace DVD drive. Good Luck!
It sounds like a hardware fault on the drive itself. The laser and focussing mechanisms are different for CDs and DVDs. The fact that the drive can read DVDs fine suggests that the laser and lenses can no longer focus correctly to deal with CDs.
Replacement of the drive would be the only fix, although you might find it a lot easier to buy an external USB DVD drive.
This is a common issue with NEC DVD burners, assuming that your NEC DVD burner cannot read and write DVDs anymore. I had a similar issue with my NEC DVD burner, which couldn't read and write CDs, but DVDs successfully. This is usually due to wear and tear of constant usage of the drive itself and sometimes mechanisms inside the DVD burner cease to work. While Windows Troubleshooting, uninstalling and re-installing the drive are suggestable, I am afraid the only option is a complete DVD burner replacement.
There would be a problem with cd reader lens
sou need to change it from the company if its in a warrenty or get it repaired from a person who is in to Chip Level Repairing
