Magellan RoadMate 300 GPS Receiver Logo
Posted on Nov 30, 2007
Magellan roadmate 300 wont turn on!
I plug my magellan roadmate 300 in and it wont turn on. I checked the fuse and it is fine. Any solutions?
  • 10 more comments
  • Anonymous Dec 10, 2007
    magellan roqdmate wont turn on
  •  Larry
    Larry May 07, 2008
    I plug unit into wall, I get 12.0vdc from the wall, i try testing unit but i have no scehmatic. I try the usb for 5 vdc but not sure where to tets that also. Magellan will not turn on.
    Any hint on test points for either the 12 vdc or 5 vdc USB?
  • Anonymous May 11, 2010
    I have found the plug for the Magellan 360 but it costs $16. This should only be a few dollar part. Is there another part number or website where I can find it cheaper?
    Does the unith power up using the AC powere adapter?
  • Anonymous Mar 16, 2014
    I need to reset the magellan roadmate 9055
    do not reset
    Magellan Roadmate 2055T-LM
    Magellan roadmate 2055T too slow after updates
    Magellan roadmate 2055T slow after updates
  • Anonymous Mar 18, 2014
    Magellan RoadMate Tools
  • Anonymous Mar 27, 2014
    I don't see a pin hole for reset.
  • Anonymous Mar 28, 2014
    no encuentro mapas de mexico compatibles con el magellan roadmate 3120-mu
Steve DeLuca
Level 1:
  • Contributor 3 Answers
  • Posted on Jan 26, 2008
Steve DeLuca
Contributor
Level 1:
Answers
Questions
0
Helped
6680
Points
12
I think the problem is with the internal power jack which tends to break. the part is MG361213 and is available at laptopjacks.com. You have to take the Unit apart and remove the old jack and resolder the new one which is a three pin unit.
Good Luck
Anonymous
Level 1:
  • Posted on Sep 29, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
10158
Points
I have the same problem using the car or ac jack. I don't want to hot wire it to the unit but I might have to. When the cord is moved the 360 powers off and at time blows the fuse in the car plug.
Can i get a instruction guide for a magellan 300
you can get a copy of your instruction manual HERE for the north american version.
for the Magellan RoadMate 300 Europe version, you can go HERE
bill
2helpful
if this is for north America model, yes. all updates for your magellan 300 can be found at the link below.
hope i have helped you today on fixya.com
2helpful
My magellan roadmate 1212 will not stay on unless plugged into
if its not charging the battery, the meter will say full even though the battery is dead..its a very common problem with alot of gps with the usb as a charging port. my solution is if this is still under warranty, i would send it back to magellan or where ever you bought it, because sooner or later the usb port is going to totally fail and wont even start up if plugged in and your going to be left with an expensive paper weight.
1helpful
Magellan roadmate 1412
Try the reset button on the side above the plug in.
2answers
Power problem
is there a reset button you can press? if not try charging it for 10 mins then try and turn it on
2answers
Magellan roadmate 300 wont stay on
It is the cigarette adapter, mine was doing the same thing until I bought a new adapter. When the old adapter plug to the GPS unit moved at all it would lose power.
1helpful
Language on Magellan Roadmate 300
You'll have to obtain a copy of the Magellan Roadmate manager disks, load them into your computer, connect the GPS to your computer using the USB cable and the use the "Roadmate Manger settings" to change the language.
Duplicate post - check this thread; http://www.fixya.com/support/t118612-magellan_roadmate_300 :)
check the fuse in the plug - usually a ring around the end that unscrews and the fuse and a small spring will be inside the small metal pin that sticks out the end. Hope this helps, please post again if not :)
Top Magellan GPS Experts
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Magellan GPS Expert? Answer questions, earn points and help others
