20 Most Recent Magellan RoadMate 2000 GPS Receiver Questions & Answers
THere is nothing wrong with it. On the left side of the unit pull up the rubber cover. You will see a very small switch and a button above it or below it.
With a a pen slid the switch, and push the re set button. Then slid the switch back. and turn on the unit the way you normally do. If it doesn't light up
either you did it wrong, the unit is discharged, or there is something wrong with it. If nothing works call Magellan and if it is still under service, they will help you. Good luck to you.
Magellan... | Answered on Aug 31, 2018
if you have a volt ohm meter see if theres voltage at the power adapter plug
Magellan... | Answered on Feb 13, 2015
sadly, get it repaired, contact manufacturer
support.magellangps.com. This is where to find an update.
Magellan... | Answered on Apr 15, 2011
The following advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050, 5310 and 6000t
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
due to some dubious "experts" on fixya, im not permitted to help you directly, but please follow the link above to get further help.
let me know if you need more help or info
Bill
Standing Member of G.O.T.
Please Support Our Troops
Magellan... | Answered on Feb 26, 2011
hi tracyw23
if you can get it to turn on, go to the system settings, then power options. while plugged in, the battery indicator should be moving from left to right if its charging. if its not moving, wiggle the cord where it goes in the 2000 and see if the meter starts charging.
the following advice pertains to the following magellan gps systems.
Bill
Magellan... | Answered on Feb 22, 2011
hi ladiestch
this is a very common problem with your model gps
Bill
Magellan... | Answered on Feb 10, 2011
You'll need to go to Megellan's website and download the drivers. This link is the only one that I could find referencing your 2000 GPS. The installation procedure shows only support for XP, so it may not work in Windows 7. The installation guide does say you must install the software prior to connecting to your PC, so the drivers are contained in the software.
http://support.magellangps.com/support/index.php?_m=downloads&_a=view&parentcategoryid=3&pcid=19&nav=0,2,16,19
Magellan... | Answered on Dec 21, 2010
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050 and 6000t
Bill
Magellan... | Answered on Dec 13, 2010
robdw71 you can get help through the link near the bottom of this post...good luck
Bill
Bill
if you have a magellan 2000 as listed in the title, the 2000 can not be charged using the USB port, you need to have a car charger or a home charger to charge that unit...only certain magellan can be charged with the usb cable, but the 2000 isnt one of them...
you can read your user manual for the 2000 HERE the link is actually for a crossover, but its the same as a 2000/crossover and the 2500...magellan has removed the 2000 from there web site for some reason, but if you read the manual in that link, all models similar to your use the USB to transfer data to your unit from the PC, the charging port is below the USB port....if you need help finding a charger, just post back and ill find you one...i get all mine off ebay for just a few dollars.
bill
Magellan... | Answered on Nov 30, 2010
hi foxylady0415,
try and run the update and make sure its fully charged and try again...you can get the update HERE
download and follow the directions exactly, and make sure the batery is either fully charged or the gps is plugged in to a good charger.
let me know if you need further help
Bill
Magellan... | Answered on Nov 16, 2010
try it on a computer running XP sp2 or 3 ..i dont have windows 7 so im not sure why its not hooking up..i know even with Xp sp3 it will install and i can update my 2000 but its not seen in the computer as a drive, but the update will install.
bill
Magellan RoadMate 2000 GPS Receiver Logo
86 questions posted
Top Magellan GPS Experts
Marvin
Marvin
Damen Wong
Damen Wong
Are you a Magellan GPS Expert? Answer questions, earn points and help others
View Most Popular
RoadMate Magellan
  • RoadMate Magellan
Most Popular Question
cracked screen
  • GPS
