Dell Latitude C610 Notebook Logo
Posted on Aug 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dell latitude problem!!!!!
Every time i close my dell laptop, to put it on standby, and then open it again, there is a big black border around the outside, its not the resolution, but , to fix it for the time im on it, i have to go to the settings on the desktop and make the screen resolution 1024 by 768 pixles. but the thing that bugs me is that everytime i shut down/close lid, it just makes that black border, and the screen small. thanks for your help.
wings_it
Level 2:
Scholar:
  • Expert 141 Answers
  • Posted on Aug 12, 2009
wings_it
Expert
Level 2:
Scholar:
Answers
141
Questions
Helped
36104
Points
363
The cable connecting the motherboard to the screen might have a few open wire. It's why the problem occur when you move the lid.
download the service manual to have access to this cable (HERE: : http://www.elhvb.com/mobokive/edwin/laptops/Dell/LATITUDE/C510-610/C510-610.PDF)
Unwrap very gently the cable from is sticky tape and you should find a dozen of very small wire, one or two might need to be reconnected together.
Or You might also have a problem with the VGA card, in that case your only chance is to find a replacement one on ebay, or if the VGA card is integrated to the motherboard, then....live with it.
You should find all the details on the service manual.
Good luck tell me if it did solve anything, and please rate..
cheers
Reinstalled Windows 7 on Dell 5720 now have black border on display
connect an external monitor/tv/display and look at the patterns of the external display. If it's clean, that means your display is the one damaged. Reinstalling windows won't help at all.
Try touching, moving, pulling, pushing the display from the top edges, and if you see any change on that border, you can tell the cause.
Usually the cause of this black bands to appear are for miss using the opening or closing of the displays, that is, using one corner to open or close the screen.
Hope that helps.
Al
1helpful
The laptop screen is almost blank/black. an external monitor is working ok. when i close the lid of the laptop and open it again the screen comes on for a sec but then goes off again almost blank/black....
As per Dell Technical support LCD kit needs to be Replaced.
I Would recommend to
Run PSA Diagnostics. Check for PSA Error codes
if unable see display during PSA Diagnostics use External monitor to make note of Error code.
Check Error code on support.dell.com
If no Error codes. Then Only option is replace LCD kit
3helpful
4answers
HELP! Laptop screen has shrunk... black border on screen.
Big Lebowski - this refers to an issue with a laptop.
No CRT on a laptop.
It is more likely a driver issue.
Go to dell.com, look for support, put in your service tag & update the graphics drivers.
Dell D610 Screen Black, But Power Still On
Hi my name is Eric,
I hope I can help you with your isue,
 Thats the way these dells are, the standby mode sometimes puts it in hibernation.
Check the settings in the screen saver/ power area
If I have helped you pleae click accept
we can till post until the post expires
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
2helpful
3answers
Screen resolution change = black border around small screen
Once you change the resolution to a smaller size and you see the black border, go into the monitor's menu and there should be settings for the Horizontal and Vertical size/position. Adjust those until it looks correct.
I hope this helps :)
Best Regards,
James
2helpful
RIGTH CLICK THEN DISCKTOP THEN PROPERTIES,DESPLAY AD SETTING, CHANGE INTO 1024 BY 768 PEXILS.... TO FIT THE SCREEN RESOLUTION 32BIT ONLY
D800 laptop will not display on external monitor
Most laptops go into standby mode when the lid is closed. To stop this, (Windows XP) click Start, Control Panel, Performance and Maintenance, Power Options, then click on the Advanced tab, select "Do nothing" in the drop-down for "When I close the lid of my portable computer"
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
