Televison & Video Logo
Posted on Aug 10, 2009
I lost the list of brand codes for the sr4105wm remote. i've been trying to use the code search mode but it is not working. my tv is a mitsubishi do u have the code?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 10, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
28
Points
I need to program the control plilips in my tv jvc
1helpful
Need codes for Mitsubishi electric tv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
Just bought a redo remote control for Mitsubishi tv. When I press input to change it jumps left and right two spaces. Can not get it to stop on HDM1?
Programming Notes
How change tv mode to av mode coz lost the remote ..and i got remote in shop but it is not working so pls help
Set the remote with an other set-up code said for your device. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
Programming Notes
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window " to get gathered related posts.
Can you help me with codes to program my vcr to remote
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Programming Notes
I have a total control tv and teletext remote and I've lost the manual and the code for a Samsung tv so I don't know how to set it up or what code to put help?
Try this link to download the manual. If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
I bought a Radio Shack universal remote. It does not list Element codes. I've done the suggestions but it doesn't work. What are Element's codes??
hello!
"Element" codes could be: Polaroid, MAG, LG, Vizio.
Have you tried "code search" mode on universal remote? If you won't find the luck of those "brands" I suggested, do "code search". Refer to remote's owners manual. I did the same for myself: obtained RCA convertor box, without remote, RCA codes won't work, RCA is out of TV business. By using "code search" I made it work. Then, you may want to do "code retrieval" option, to know the correct code.
good luck,
Alex.
33helpful
3answers
Access codes for One for all URC4640
SEARCHING FOR YOUR CODE
remote control after trying all codes
listed for your brand, or if your brand is
not listed at all, try searching for your
code. For example, to search for a code
for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED
blinks twice, then release SET.
3. Enter 9 - 9 - 1.The LED will
blink twice.
4. Aim the remote control at the the
TV and slowly alternate between
pressing POWER and TV. Stop when
the TV turns off.
NOTE: In the search mode, the remote
control will send IR codes from its library
to the selected device, starting with the
most popular code first.
5. To lock in the code, press and hold
SET until the LED blinks twice, then
release SET.
6. To search for the codes of your other
devices, repeat steps 1 through 5, but
substitute the appropriate device key
for the device you are searching for.
I found this off a urc-4605 manual online but I think it works for all models worked for my urc4640b00
ETEC REMOTE CONTROL MODEL RC5
http://homenol.blogspot.com/
Programming Notes
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
2answers
Universal remote codes
Hi jamie, did you remember the procedure to scan for the codes ? Normally if your TV is not listed on the manual, you can execute the search mode ponting to the TV. As soon as the TV turns on, press the accept key on the remote. I had the sam problem, luckily I remembered the scan procedure. I have 3 different brand of remote controls, all with scan capability but diffeent key strokes.
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
