Touchscreen is on another user, made up by a 4 year old, and I cant get it back to mine nor can I get a plugged in keyboard to work
Well the KID , created her own account
so log off or sign off or shut down the PC
then turn it on from dead cold and at the windows
screen login PICK YOURS not HERS.
if the child scrambled the PC to the max. (sure can happen easy)
then do the manual stated full recovery back to day one new.
all YOUR data gone.
why not buy and old PC and let the kid play with it.
windows is not kid proof at all,
the full recover is here.
in the BOOK , RTM?
main support here.
https://www.dell.com/support/home/us/en/04/product-support/product/inspiron-20-3052-aio/manuals
your page is here. click PDF me and my dell, this one.
then read page.
65up. chapter "REcovery"
Hi Martha as you are not telling us what version of windows you using I am going to assume its win 7 so to get you machine back to factory default settings. turn on your computer as soon as the dell logo appears, press the F8 key and you should get a menu click the dell factory image restore this will put you machine back to its default settings, you will lose all data, this will only work if your machine is still configured as delivered by Dell.
SOURCE: Dell D600 LCD issue
What I've found on two laptops I've worked on in the past two years is that in a case like this, there is a little pin near the power button (or on the strip up near the display) that tells the laptop when the monitor is closed. If that pin gets stuck, the computer will think it's shut all of the time. The sensor is only active in normal mode of windows with the drivers installed (if it's in safe mode or VGA mode the sensor does not work until you raise the resolution. the sensor doesn't work at all if you boot from a knoppix cd.)
You may be able to just flick the pin and get it unstuck, but in some cases you have to remove it all togther.
To remove it, turn the lapotp off. lean the monitor back as far as it can go (don't force it). You then need to carefuly pry up the strip that the power button is on (ussually there is a space you can pry open on the left or right side of the strip depending on the model laptop; be very careful not to break anything). You can then pop it out with a small knife or tweesers and clip the strip back down.
If you don't feel comfortable doing this, then find someone who is.
I hope this helps someone.
SOURCE: dell inspiron 1100 laptop screen won't light up
Sounds like a back light problem, power reset it, pull out the battery and ac adapter and then hold the power button for 1 minute, then replace the power cord and battery and start it up, if it doesn't work try calling dell to see if you can get it repaired under warranty if it is out of warranty take it to a shop.
SOURCE: Blank screen on desktop (dell inspiron 530s); requesting a password.
Someone has turned on the BIOS password on you and therefore the PC will not let you boot up unless you enter the correct password. The problem is you cannot turn off the password option unless you know the password. I would start by asking other people who had access to you computer what they set the password to. If nobody comes clean, then you will have to call Dell Tech Support to get them to reset the password for you. They will give you a master BIOS password to override the one set and turn off the option.
SOURCE: My Dell Inspiron 1525 wont load up
I'd suggest first removing your memory modules and reinsert one at a time.
But, I think your operating system is compromised, due to Spyware, etc.
Since your system won't boot in Safe Mode, your only other option is to repair or reinstall your operating system.
Hope this helps.
SOURCE: dell inspiron 5150 laptop, reset admin. password.
Restart your laptop and keep tapping F8 key the moment you see something on the screen. You will get a black screen with some options written in white. Select the option Safe mode and then you can create a new user with admin rights. Or else at the windows login screen press and hold ctrl and alt key and tap delete key twice and then it will take you to a login screen. Dont put any password there just hit enter. And you will be able to login with admin rights.
Thanks
Deepak
