When the clothes are spun dry and the dry cycle is set, water rushes into the drum and soaks the already spun dry clothes.
A call to the repair service resulted in this info: it's a problem with the software...a quirk in the system. we are aware of it. try to run the dry cycle for a few minutes; if the drum does not fill with water, then add the spun dry clothes. i've done this too many times, with water filling the drum, and not draining out. help!
The problem lies with the water valve at the water entrance area; trace the pipe from where the water comes to dispenser. This should be done after opening up the top ( careful not to touch any part which could give you electric shock or anything) The pipe where the water gushes should be traced back to the inlet area, you will have to change this valve. To see the gush gently open the dispenser drawer.
THis sounds like it's a job for a licensed repairman.
Clothes are spun dry at end of wash - soaking wet, with water collected at bottom of drum, at end of dry cycle.
Same problem, but know the spin cycle won't work either
