Refrigerators Logo
Michael Myers Posted on Mar 07, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Whirlpool side by side refrigerator (ref: S20EF1123). The freezer and fridge temp readings keep flashing and clicking. I have bought a replacement PCB, but that has not fixed the problem. Is there a reset sequence I need to try? Is there a known fix to this issue? Any help appreciated - it’s driving me crazy! Thanks :)
Here2HelpYou
Level 3:
Master:
  • Master 592 Answers
  • Posted on Mar 18, 2019
Here2HelpYou
Master
Level 3:
Master:
Answers
592
Questions
0
Helped
152865
Points
4122
I'd suggest contacting Whirlpool Customer service by phone or go to the link I'll post below to chat live from your phone or computer immediately- I prefer this way personally and would reccomemd it! I apologize for this fairly generic answer but it really is the best thing to do sometimes. They're familiar with their products and their respective issues more so than anyone, so email or call them, I'll add the contact information, best of luck!
LINK TO WHIRLPOOL CUSTOMER SERVICE PAGE INCLUDING LIVE CHAT: Contact Us
5 Related Answers
Anonymous
  • 410 Answers
  • Posted on Jan 07, 2008
SOURCE: WHIRLPOOL GS6SHEXNL00 SIDE BY SIDE REFRIGERATOR LIGHT
funny you asked this question i just had this same problem this week at a customers home. you need the electronic control board located in the compressor compartment behind the refrig. it is mounted in the white box on the left hand rear corner. the whirlpool part number is 2304095 and it is around 175.00 i'm not sure who a local part supplier around you would be if all else fails you could get thru sears..
themackshack
  • 27 Answers
  • Posted on Feb 02, 2008
SOURCE: WHIRLPOOL CONTROL PANEL
Hi. Your temperature control board display is bad. You may also have a power convertor board located next to the compressor. Normally you would replace the temperature control board first. I have a temperature control board listed on Ebay as item number 250211412492. Good luck, Mack
skotkolr
Scott Hill
  • 558 Answers
  • Posted on May 27, 2008
SOURCE: Fridge and Freezer losing cooling
thermostat control to deice the freezer is malfunctioning need a service tech to replace it so it doesn't keep the deicer on . Its exactly that, a warmer to deice the coils.
Anonymous
  • Posted on Feb 08, 2010
SOURCE: whirlpool S20B RSB21
If you look on e-bay, there is a chap in the UK selling repair kits. If you are reasonably mechanically minded and handy with a soldering iron, and happy to remove components on a PCB and replace them you can fix all of your issues in about an hour. The kit costs £35 with full instructions and also you can phone him for advice. It consists of a number of capacitors (as per solution #1 plus several others). I fixed mine over the weekend and am delighted with the results, no need to pay hundreds for the the boards from whirlpool!!
Anonymous
  • Posted on Apr 19, 2010
SOURCE: Whirlpool American Fridge Freezer Clicking noise
my whirlpool amerian side by side it has got warning sign on with a ! at it has stop frezzing
Testimonial: "Thanks very much for your help, really appreciate it "
Fridge is not cooling. Lights work and fan could be heard and Ticking noise. Problem with the Whirlpool Gold White-on-White 22.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD27DF Side...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Whirlpool side by side fridge is warm but the freezer is working good
NOTE: This
MORE
TIPS AND TRICKS:
Leo Ponder
imufo2
Whirlpool side by side 6th sense fridge silver continuous beeping
NOTE: This
MORE
TIPS AND TRICKS:
Leo Ponder
imufo2
Whirlpool american fridgefreezer just turned it on at mains the temp for fridge if fine but no temp showing for freezer and a triangle red light flashing and makeing a bleeping noise
NOTE: This
MORE
TIPS AND TRICKS:
Leo Ponder
imufo2
I have a whirlpool arc4170 fridge/freezer. The fridge is not cool and the top of the freezer is not cool but the bottom seems ok. Any idea as to what is wrong?
NOTE: This
If
MORE
TIPS AND TRICKS:
Leo Ponder
imufo2
Whirlpool Gold side by side fridge with ice maker, model #GS5SHGXLS00, running, but not cooling.
NOTE: This
If
MORE
TIPS AND TRICKS:
Leo Ponder
imufo2
2helpful
2answers
Whirlpool refrigerator not cooling in fridge section or freezer section but it is running, just no cold air....all food had to be tossed as it was warm. This is model #et8ghmxlq02
NOTE: This
If
MORE
TIPS AND TRICKS:
Leo Ponder
imufo2
Freezer light flashing, fridge not as cold as it should be and motor constantly running. There was an ice build up on the bottom shels of the freezer
NOTE: This
Then check to see if FREEZER CONTROL is turned warmer which makes REF. colder or vice versa.
Also this might be a common Defrost problem, Ice
MORE TIPS AND TRICKS:
Leo Ponder
imufo2
Whirlpool 747l fridge, temperature alarm comes on a couple of times a day on the freezer, goes away anywhere between 5 mins and 5 hours. I have checked the condenser and that the vents in the freezer are...
NOTE: This
Leo Ponder
imufo2
12helpful
Whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted
whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted. the temp display on freezer shows - - flashing
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
