Vacuums Logo
p
phil leonoudakis Posted on Feb 19, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Floor scrubber tenant 5700 brushes will not lower
Stephen Miller
Level 3:
  • Vacuums Master 1,645 Answers
  • Posted on Feb 27, 2019
Stephen Miller
Vacuums Master
Level 3:
Answers
1645
Questions
0
Helped
866192
Points
9471
1 Related Answer
Anonymous
  • 43501 Answers
  • Posted on Sep 30, 2010
SOURCE: we have a 2x brushes bissell carpet scrubber. Do
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
x
Clarke scrubbers
If you attach a picture of the scrubber, and give the model number, I can help. I retired from repairing these floor machines after 30 years. I like Clarke machines.
1helpful
2answers
1helpful
Scrubber brush does not spin
There is a plastic piece on the back of the block brush (spin scrubbers) these wear out or break. You may need to replace the block brush. You can find the parts and a schematic below follow the link. Please don't forget to give positive feedback.
F5914-900 Link
http://www.usavacuum.com/F5903-s/138.htm
My brushes on my hoover steamvac all terrain carpet and hard floor cleaner will not spin what do i do
I am not sure if you have the F7222 or F7452 all terran. There is a plastic piece on the back of the block brush (spin scrubbers) these wear out or break. You may need to replace the block brush. You can find the parts below follow the link. Please don't forget to give positive feedback.
Hoover F7XXX Link
http://www.usavacuum.com/Hoover-Steamvac-s/107.htm
I have a Lux Floor Pro Heavy Duty carpet cleaner. Whis attachments (scrubbers) do I attach to the bottom to wash a non-plush carpet. I have three attachments that have hard bristles and three that have...
NEVER USE THE HARD BRUSHES ON CARPET ! You can burn up your motor, break the drive belt,or strip the drive gears The black bristle brushes are for all carpet types.
The hard bristle brushes are made for hardwood and other smooth surfaces.
My hoover carpet scrubber the brushes won
(1) Remove the brush block and assure the presence of the square drive pin on top of one brush. It should be about 1/4 inch square, two inches long to connect o the drive mechanism.
(2) Remove and clean the filter screen from the base, behind the brushes. Squeeze the two red tabs together, and pull down from the base. Clean the hiar/debris from the screen.
(3) Assure the Brush Speed knob on the hood is NOT set to the OFF position.
Have a Hoover Model F5887-900 upright carpet cleaner. I am having issues with the attatchments. The brushes will not spin on the handheld attatchment and the solution trickles out. Any...
HI ,
I AM BILL AND I HAVE A SIMILAR PROBLEM. I HAVE FOUND THAT THERE IS A SHIFTER VALVE NEAR THE REAR OF THE MOTOR AREA.
IF YOU LAY THE HANDLE DOWN FLAT YOU CAN SEE WHERE THE VACUUM HOSE ATTACHES TO THE SUCTION MOTOR. CHECK THERE TO SEE IF IT HAS COME APART.
NEXT CHECK THE SHIFTER VALVE AND SPRING MOVE ROTATE 1/3 OF A TURN . WHEN YOU LOWER THE HANDLE THE SHIFTER HAS TO BE IN THE FLOOR MODE FOR THE SUCTION TO THE MAIN FLOOR SCRUBBER AND SPIN THE BRUSHES.
TO USE HAND TOOLS THE HANDLE HAS TO RAISE UP AND LOCK TO OPERATE ANY HAND TOOLS.
A PLASTIC LEVER BREAKS BY A SPRING CALLED THE SHIFTING LEVER. A SHIFTER VALVE LEVER IS THE RIGHT REAR, THE HANDLE DOWN. GOOD LUCK
MY PROBLEM ACTUALLY THE SHIFTER DOOR AND I HAVE A LOT OF SEARCHING TO DO TO FIND THAT.
OH! BY THE WAY THE LEVER PART # IS 90001320 $2.16 + SHIPPING AT SEARS PARTS DIRECT
Apr 29, 2009 • Vacuums
Nilfisk advance floor scrubber vacuum problem
CAN YOU HELP? I AM LOOKING FOR A SMALL FLOOR POLISHER AND SCRUBBER FOR MY OWN USE AT HOME. i SHOULD HAV TWO 5_6" SCRUBBER PADS AND FLOOR POLISHING PADS. THANK YOU AND GOD BLEES. [email protected] LOWTON , OK
Mar 12, 2008 • Vacuums
Rainbow e series vaccum/scubber
If you are talking about the hard wood floor brush you hook it at the end of the one slightly bent wand. Look at the end of the brush that you would hook to the wand. In the circle opening there are two slits. On the end of the wand there are two bumps. You need to line them up, push the brush on then twist it around so it stays on. then you attach the straight wand to that and the other slightly bent wand at the other end of the straight one. It will go like this Wet hose, slightly bent wand, straight wand, slightly bent wand, and floor brush. I hope I helped. Leave the basin empty. put your water or cleaner on the floor scrub it around then turn machine on and suck it up.
Top Vacuums Experts
AskDyson
AskDyson
Anonymous
Are you a Vacuum Expert? Answer questions, earn points and help others
