Haier 32" flat screen tv
SOURCE: tv is locked
I had the exact problem...tried a number of things that did not work. My dog "ate" my original remote. After reading your solution I took the universal remote that was programmed to work with the tv and tried holding down each button for a few seconds hoping that one would work like the display button on the original remote. It worked. I have a GE universal remote and the menu/info button worked for me. Again, you need to hold it in for a couple of seconds. Thanks for the help and I hope my added solution helps other people. Claudia in Minnesota
SOURCE: all buttons on tv stopped working only turns ON no ...
There is a button lock in the menu of the television. Using your remote access the menu screen and unlock the buttons.
SOURCE: Locked Tv
yes hold the volume down and volume up at the same time
and you will see the unlock menu screen at the bottom
so simple
SOURCE: remote control code for 32 inch lcd EMERSON TV
I succeeded is using the DirectTV remote control for the Emerson 42" plasma TV, by using a Samsung code. On my TV, was 10060. If this one does not work, there are a bunch of others that might work. Good luck
