Televison & Video Logo
Stephanie Posted on Nov 11, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I change the input source on a Haier TV without a remote? My TV is stuck on "composite" mode, n I lost my remote. Please help!
Sebastian Wojnarowicz
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 11, 2020
Contributor
Level 1:
Answers
Questions
0
Helped
14399
Points
Press input, scroll to desired input using channel botton. Press volume botton
Clam Chowder
Level 1:
  • Posted on Mar 23, 2020
Clam Chowder
Contributor
Level 1:
Answers
Questions
0
Helped
14399
Points
Hey so my boyfriend just flexed on me by proving that y’all saying u need the remote are wrong. I swear I tried this before he came in, but it worked when he did it for some reason and not when I did. Hold the input on the bottom/side of the tv, and press the channel down/up button.
Marvin
Level 3:
Top Expert:
  • Haier Master 85,242 Answers
  • Posted on Nov 11, 2016
Marvin
Haier Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29169760
Points
266283
You need the remote to access these functions. You can buy a new one most likely here: www.remotes.com
5 Related Answers
Anonymous
  • Posted on Mar 01, 2008
SOURCE: sanyo stuck on video mode
Yippie, I figured out a solution that worked!!! I have a univeral remote from comcast, on that remote near the bottom left is a small button that says (input) tv/vcr, press that one time and whala!! the tv video screen was gone, I had to manually change the channel from the tv channel button on the unit. once I changed the channel to 3, my universal remote worked... the button is the second one from the bottom left... I was on hold with sanyo for a long time and just kept trying on my own, so good luck!!!!
Anonymous
  • 1284 Answers
  • Posted on Feb 23, 2007
SOURCE: How do I change the input without the remote
If there is no nutton on the TV to do so then you have to have the remote for it. You can try a universal remote but, usually functions like that don't work. Here is a link to the remote you need. http://www.electronicadventure.us/Merchant2/merchant.mv?screen=prod&store_code=EA&product_code=6450348129
Anonymous
  • Posted on Jan 04, 2009
SOURCE: Help with Game Mode/Channel Switch Please!
there is this remote set up like a dvd remote and it has 3 or 4 diffrent ways to get into the game mode
Anonymous
  • Posted on Jan 26, 2009
SOURCE: lost remote to 27in rca tv, how can i switch my tv to input/output mode so i can watch movies on my dvd playter?
using the menu button on the t.v. set an alarm for 1 min in the future. have the t.v change to channel 00 or the input channel @ that time. turn off the t.v and wait until the alarm turns the t.v on.
Anonymous
  • 790 Answers
  • Posted on Apr 10, 2009
SOURCE: i need to switch my tv to input without a remote
Hi
please use the menu button in your front panel then search the video, Air, or Cable selection!
Thanks!
I need to know how to change modes without controller when I'm using a dvd
Without a remote controller, you may have limited options to change modes on your Apex digital TV. However, you may be able to change the mode by using the buttons on the TV itself.
Here are some general steps you can try:
  1. Turn on your TV and make sure your DVD player is connected to it.
  2. Look for the "Menu" button on the TV and press it.
  3. Navigate through the menu options using the arrow buttons on the TV until you find "Input" or "Source."
  4. Press the "Enter" button to select the input/source option.
  5. Use the arrow buttons to select the input/source that corresponds to your DVD player.
  6. Press the "Enter" button to confirm the selection.
  7. Press the "Menu" button to exit the menu.
Note that the specific steps may vary depending on the model of your Apex TV. You may also consult the user manual for your TV for more information on changing modes without a remote controller.
What channel on the hci tv can I view my dvd I hooked the red yellow and white jacks into the back of tv but cannot find a channel to view the dvd
You probably need to find a Source or Input button or menu item. Change the source from TV (if that is your current source) to A/V (or composite video). Depending on the model, there may be a source/input button on the TV. There will always be a sourc/input button on the original remote. If you are using a universal remote, you may need to try a different code to get the function to work.
On a few TVs, you can find this in one of the sub-menus. However not all TVs let you change the source in the Menu system.
I hope this helps. Please add a comment with the model of the HCI TV and whether you have the original remote or a universal remote to control the TV if you would like me to find the specific information for your TV.
(For example, the HCI RM22 III remote has the input button on the left side just below the power button.)
1helpful
How best connect external DVD to TV: Composite or Component? Both available on both units
If the TV does have a component input, that will be your best choice. Component video provides an HD signal; composite is only an SD (480i) signal. However, if the TV doesn't have 3 RCA ports (red, green and blue) for the video itself, in addition to the red/white RCA audio ports, you may be missing an adapter that allows the port to be used properly. You'll need to set the TV to the external video input with a Source or Input button on the TV or the remote. If you press the DVD button on the remote, the TV will only attempt to get the signal from the internal DVD.
Please add a comment with the make and model of your TV for additional information. A number of TVs (like some LG models) share the composite and component inputs and use an adapter to reduce the input to a smaller area on the TV. Without the adapter, the TV can't correctly identify the signal. The component video adapter for my LG TV looks like this: http://www.amazon.com/LG-OEM-Original-Part-EAD61273107/dp/B00C5HXILE . There's a second one for the audio signal.)
I hope this helps.
Isn't this just a simple hookup? What am I not doing?
You either need to change the input source. Currently the source is TV, depending on how you connected the DVD player to the TV, it should be composite (A/V), component video or HDMI. (S-video is also a possibility. Very few DVD players are connected on the RF (coax) input which might be channel 3 or 4 without having a converter between the DVD player and the TV.)
Look on your TV remote for a button marked Source or Input. You may also find this button on the TV. (On some TVs, this may also be accessed through the menus.)
How did you connect the TV and the DVD player? If your audio and video were connected via three RCA plugs (yellow, red, white) on each end, then use the composite video input. If you used cables with 3 RCA plugs for video (yellow, green, blue) and 2 for audio (red/white), then switch to the component input. If you used HDMI which carries audio and video in one cable (with rectangular ends), then use the HDMI input.
Some older TVs only have the Source/Input button on their original remote. Not all universal replacement remotes have this button, you may need a different remote. Those that do may require you to try additional codes for your TV manufacturer to enable the button. (The on./off buttons often will work with more of the codes for a brand.) The ones that can be programmed via a USB connection to a computer are most likely to support the function. Please add a comment with the type of TV for additional help with this.
I hope this helps.
I cant hook up the red,white, and yellow wires to my magnavox tv
If you mean that the TV doesn't have a set of composite video/audio jacks, then you need a converter for the inputs on the TV. (Most likely you need a video converter (RF modulator) that converts the game console composite video to RF (coax) and set the TV to channel 3 or 4 usually. RF modulators are available from stores like Radio Shack for $30.)
If you have a TV with a composite video input and can't get the game console to view, then there is a different problem. First try new cables. Switch your input as needed for both the TV and the game system. This will depend on the TV and if you have the original remote/unlocked front panel buttons on the TV or a substitute remote that maintains all of the features of the original remote. On some TVs you can cycle through to the A/V inputs by increasing (or decreasing) the channels until you are between channel 2 and the highest available channel. (This doesn't always work if the TV has been programmed to skip channels that previously had no signal.) Otherwise look for a Source or Input button on the remote or TV (or an OSD menu (sub menu) that lets you change the source).
I hope this helps.
Girlfriend lost remote for RCA F27645. I know I
If I'm Correct There Is Only One Set Of Inputs On That Model TV. What Inputs R U Reffering To?
Stuck on a video mode
Some TV's disable inputs if there is no signal. I suggest confirming cables are connected properly, and accessing the system menu, and perform an autoscan for channels
2answers
How to change from video mode to cable/Antenna Input without a Remote
Alot of Zeniths have menu for that, have you tried to press the channel up button?
Top Haier Televison & Video Experts
Paul Bade
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
