Question about Haier HL42E LCD TV
I have problems with my LCD HAIER TV. I put my USB and now i cant return to TV Mode. What i should do?
Posted by hehuerta on
sreejithnait
    New Friend:
Sir , i have a new problem with my new haier l32m3 .the problem is there is no usb movie,so what can i do? any remedies for watching movies
Posted on Apr 18, 2012
Anonymous
    New Friend:
There should be a button on your remote that says "TV/USB". Try clicking it, that should take you to a blue screen that says No Signal, click Input, and you should be able to access your cable from the list of Input sources. This happened to me today, very annoying and unnecessarily confusing, especially since most buttons you press result in a screen that reads "Not Available." Urrgghhh.
Posted on Mar 02, 2010
Wanda Longa
    New Friend:
  • 3 Answers
Press on you remote repeatedly the keay "back", the screen will turn blue, then press "input" and select your option, it should work.
Posted on Oct 28, 2014
  • Wanda Longa
    Wanda Longa Oct 28, 2014
    press on you remote repeatedly the keay "back", the screen will turn blue, then press "input" and select your option, it should work.
Jason Lumley
    New Friend:
Look for the button that has a square box with a arrow pointing to the right should be a small round button on right side of your remote or you can look to right side of your tv and hit the top button which has a picture of a box with right arrow in it that is your video source button or input button allowing you to switch from tv to video hdmi or usb I was confused since I never seen a tv like it as I was helping a friend tonight fix his tv as he switched it somehow and could not get his direct tv to work cause it was on the wrong input but hope that should help solve your problem I was able to fix his tv after figuring it out lol.
Posted on Nov 19, 2013
Anonymous
    New Friend:
Sir i have a problem with the LCD l32m3,i cant watch any movies while i inserting the USB
Posted on Sep 01, 2011
1helpful
My Haier tv is stuck on USB screen. We don't have anything connected in a USB port (the screen also says there is no USB drive connected). Is there a way to do a hard reset on the tv?
Try to connect a USB pendrive and maybe you can wake up your TV. btw, bad news, Haier is a really cheapo brand
If no luck, return it for warranty, if haven't expired yet. and even if it's past warranty, I would try to claim assistance!.
My haier tv stayed in USB mode and just froze there off and on probe responds to the control and nothing. prove with the buttons on tv and neither worked
I have problem with my haier tv with the sound and i use in antenna it dosnt have a sound
check it with your remote it might selected to mute mode, if not, its either your speaker or sound ic amplifier output..
3answers
My brand new flat screen haier tv 39'' is flashing white then red green then blue and black screens how do i fix
Try to disconnect the set and a box if being used from power for a while and then power both back as either could cause this problem.
3helpful
2answers
WHAT IS THE PORT UNDER THE HAIER 7 LCD THAT SAYs update HOW DO I USE THIS FEATURE WHAT IS IT USED FOR DOES THIS UPDATE THE TV ?????
This is a Star Trek GNDN USB mini port for the Haier factory to update the firmware (software stored permanently) in the TV.
If you return the set to Haier for servicing under the 90 days labor, 1 year parts warranty, Haier will probably just send you a refurbished unit.
Part of the refurbishment is for the Haier factory to update the software which runs this digital TV.
If you connect your computer to the port with the correct cable, nothing will happen.
No drivers or user mods (hacks) appear to be available.
Need three digit code to access DISH network remote for a Haier HL19R1a
We would be happy to help. We currently do not have anycodes specifically for your Haier TV. We would recommend performing apower scan. If there is a code that is compatible with your TV the power scanwill find it. Power scan instructions:
Step 1:
Press and hold the TV mode button until all mode button back lights illuminate,then release.
Step 2:
Press and release the Power button.
Step 3:
Press the Up button once per second while pointing the remote at the desiredequipment. If the code for the equipment comes up, the equipment will poweroff.
Step 4:
Press the pound (#) button. If the code entered is valid for the remote, themode light flashes three times.
After doing the power scan please remember to put the remote back into SAT mode.Thanks so much for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Haier HL42E LCD TV Logo
Top Haier Televison & Video Experts
Kolbrun...
Paul Bade
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
