20 Most Recent Sharp AQUOS LC-32D44U 32 in. LCD TV Questions & Answers
if you want to watch the full version of that movie then you must chick on the link shown
Sharp AQUOS... | Answered on Jun 13, 2018
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sharp AQUOS... | Answered on Apr 02, 2017
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Sharp AQUOS... | Answered on Jan 13, 2017
Could be an open internal fuse or power supply failure
Sharp AQUOS... | Answered on Dec 06, 2016
hook it up to an outdoor antenna , do a channel scan with the input set to AIR or antenna
Sharp AQUOS... | Answered on Jul 16, 2016
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sharp AQUOS... | Answered on May 08, 2016
Please follow as per attached.
Sharp AQUOS... | Answered on Jan 13, 2016
Remove Mains Plug and press Standby switch from LED Panel for 30 sec. Press Input & Ch Down Switch from LED panel and plug in and start LED LED will start and "K" will appear on screen Press Ch Down & Vol Down switch at same time You will get 1/10 page on screen Go to 9/10 page by pressing left & right button from remote Select EEP and press Ok button from remote After 30Sec remove main plug and restart LED.
Sharp AQUOS... | Answered on Dec 24, 2015
look for buttons on the side of it .
Sharp AQUOS... | Answered on Nov 13, 2015
probably the power supply is faulty. Just watch the bellow added video to understand how to check the power supply a flat panel tv .
Testing LCD TV Power Supply BoardsSTEP BY STEP
Sharp AQUOS... | Answered on Nov 03, 2015
You have to go the menu of the tv and have to change aspect ration setting to 16:9. Here i have added the link the the manual of the tv which will help you to know how you access the settings.
www.electro-medical.blogspot.com
Sharp Aquos LC 32D44U Operation Manual
Sharp AQUOS... | Answered on Sep 11, 2015
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Sharp AQUOS... | Answered on Sep 10, 2015
Can you tell me where is the area to locate R7637? I have a power supply but can't find that part.
The service manual doesn't have a part list to find that resistor.
Sharp AQUOS... | Answered on Sep 06, 2015
Sharp AQUOS LC-32D44U 32 in. LCD TV Logo
232 questions posted
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
Aquos Sharp
  • Aquos Sharp
Most Popular Question
dont secret code ive tried 0000 1234
  • Televison & Video
