If your dryer doesn't heat, check these:
Power from the houseHeating elementThermal fuseWiring
Checkto see whether there's power getting to the dryer. Is it plugged in?Check for blown fuses or tripped circuit breakers--your dryer uses twofuses or circuit breakers. The dryer could tumble but not heat if onlyone of the two fuses is blown. If you have circuit breakers, one of thetwo circuit breakers can trip, even if the two for the dryer areconnected.
Heating element
Oftena dryer heating element burns out, but doesn't trip the circuit breakeror blow a fuse. The heating element is simply a long coil of specialwire. You can check it for continuity with an ohm meter. No continuitymeans the element is bad and you need to replace it--electric heatingelements aren't repairable.
Thermal fuse
Onmany dryers, there's a thermal fuse mounted to the exhaust duct insidethe back cover panel. The fuse--which is about an inch long--is usuallyembedded in black resin and mounted in a white plastic housing. If thefuse has blown, you need to replace it. (You can't re-set it.)
Wiring
Acommon problem is for the main wiring connection from the house, at thedryer, to burn and break its connection. Because the dryer can stilltumble with partial power, the connection may be only partiallydefective. You may need to replace both the power cord to the dryer andthe terminal block inside the dryer that the wire is attached to.
