20 Most Recent Honda Eu3000is Questions & Answers
Eu3000is Manual
Honda Eu3000is | Uploaded on May 10, 2018
Check the ground wire that goes from the negative side of the battery to the engine block. I have seen them break at the connection on the block. You can test to see if it is broken by connecting a wire from the ground lug on the side of the generator and holding it to a bolt on the side of the engine and see if it will start. Also the low oil sensor will prevent the spark if you are low on oil.
Honda Eu3000is | Answered on Sep 15, 2014
Inverter Generator Benefits
  • The EU3000 series generators are inverter generators. The generator features an alternator, which produced high-voltage, multi-phase AC power. This power is converted to DC power and then converted back to AC. This process is controlled by a microprocessor and is necessary to provide stable, consistent power capable of running equipment sensitive to power surges. This type of generator provides higher fuel efficiency and lower operational noise ratings in a lighter model than home and work generators produced by Honda.
EU3000i Handi Specifications
  • The Honda EU3000i Handi is a 3,000-watt inverter generator that features wheels, folding handle and a recessed convenience light. The engine is a Honda GX160, which features a 163-cc displacement. The AC output is 120 volts, with an average rating of 2,600 watts and a maximum production of 3,000 watts. There are three receptacles to include a 20A, 125-volt duplex and a 30A, 125-volt locking plug. The DC output is 12 volts and 100 watts. The EU3000i can hold 1.56 gallons of unleaded fuel, which will provide consumers with 3.6 hours of run time at 25 percent load for 7.7 hours.
performance chips of BMW.
Honda Eu3000is | Answered on May 31, 2012
These are all messages that follow overheating. E.nOH indicates that the heat sink has returned to the normal temperature range and the unit can be reset. E. OH indicates that the power module is over-temperature. This could be caused by insufficient air flow at the heat sink. That is caused by dust/dirt. The ventilator could be clogged or the ambient temperature is too high. E. OH2 indicates that the motor protection relay was tripped. Check for dust/dirt and clean any filters. Make sure that nothing is blocking the air flow around the unit.
KEB uses these error mesages on the CombiVert F6, https://www.keb.de/fileadmin/media/Manuals/f5/control/f5m/00f5mebk320.pdf .
I hope this helps.
Electronics -... | Answered on Jun 01, 2019
Hello Shakeel, the PG156R diode, you can replace it with any fast diode of 1000 Volts, 3 Amper
I send you a link for you to unload the PG156R datasheet and another about the replacement
I hope you can solve the problem
Greetings Franco Dosil
Hola Shakeel, el diodo PG156R, lo puedes reemplazar por cualquier diodo rapido de 1000 Volts, 3 Amper
te envio un link para que descargues el datasheet de PG156R y otro sobre el reemplazo
Espero puedas solucionar el problema
Saludos Franco Dosil
https://pdf1.alldatasheet.com/datasheet-pdf/view/406020/PANJIT/PG156R.html https://www.yoreparo.com/tv/televisores/tubo/preguntas/1412382/puedo-reemplazar-diodo-pg156r-por-un-rg10 https://www.yoreparo.com/tv/televisores/tubo/preguntas/1284512/reemplazo-de-diodo-uf156 PG156R NTE Equivalent NTE571 1000V 3A soft recover
Electronics -... | Answered on May 28, 2019
Honda Eu3000is Logo
Popular Tags
4 questions posted
Top Honda Electronics - Others Experts
John
Level 1 Expert
Bill Boyd
Steve Allison
Steve Allison
Are you a Honda Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Honda Electronics - Others
Most Popular Question
eu3000 honda generator replaceil
  • Electronics - Others
