20 Most Recent Topcon Gpt-8205a Robotic Reflectorless Total Station Questions & Answers
These are all messages that follow overheating. E.nOH indicates that the heat sink has returned to the normal temperature range and the unit can be reset. E. OH indicates that the power module is over-temperature. This could be caused by insufficient air flow at the heat sink. That is caused by dust/dirt. The ventilator could be clogged or the ambient temperature is too high. E. OH2 indicates that the motor protection relay was tripped. Check for dust/dirt and clean any filters. Make sure that nothing is blocking the air flow around the unit.
KEB uses these error mesages on the CombiVert F6, https://www.keb.de/fileadmin/media/Manuals/f5/control/f5m/00f5mebk320.pdf .
I hope this helps.
Electronics -... | Answered on Jun 01, 2019
Hello Shakeel, the PG156R diode, you can replace it with any fast diode of 1000 Volts, 3 Amper
I send you a link for you to unload the PG156R datasheet and another about the replacement
I hope you can solve the problem
Greetings Franco Dosil
Hola Shakeel, el diodo PG156R, lo puedes reemplazar por cualquier diodo rapido de 1000 Volts, 3 Amper
te envio un link para que descargues el datasheet de PG156R y otro sobre el reemplazo
Espero puedas solucionar el problema
Saludos Franco Dosil
https://pdf1.alldatasheet.com/datasheet-pdf/view/406020/PANJIT/PG156R.html https://www.yoreparo.com/tv/televisores/tubo/preguntas/1412382/puedo-reemplazar-diodo-pg156r-por-un-rg10 https://www.yoreparo.com/tv/televisores/tubo/preguntas/1284512/reemplazo-de-diodo-uf156 PG156R NTE Equivalent NTE571 1000V 3A soft recover
Electronics -... | Answered on May 28, 2019
Connect and get best solution of email related issues. Webmailhelps
Electronics -... | Answered on May 23, 2019
Buy the best quality one you can afford. Be aware that the rated max use is not the continuous use level. Add up the total watts you want to use and buy a converter 30-50% more so there are no overload issues. Make sure the inverter is operating in an area of free flowing air for cooling purposes.
Electronics -... | Answered on May 21, 2019
Hi, guessing you are from the UK? Different countries operate different regions for dvd's for instance the UK dvd players are set up to play region 2 discs, and US dvd players are set up to play region 1 discs.
This is because dvd release dates are different around the world and this stops people buying a dvd in the US and bringing it back to the UK and selling it before its official UK release date for example.
Your choices are either to play the dvds on a PC where often the dvd software will allow you to change region a number of times (be careful though as some players will let you change region say 5 times and then be locked to that region)
Or to get hold of or buy a multi region dvd player which plkays dvd'd regardless of their original region
Hope that makes sense, good luck
Electronics -... | Answered on May 17, 2019
Hello Mehboob, you could send a photo of the component and if you do not have it, comment on which diagram you are in
I hope you answer
Hola Mehboob, podr?as mandar una foto del componente y si es que no lo tienes, comentar en que diagrama se encuentra
Espero te respuesta
Electronics -... | Answered on May 14, 2019
Same thing happens to me .My 8gb silicon usb flash drive got the same error, please insert a disk into drive, the name of my drive weas changed into Removable Disk instead of the name(Sanctuary which is what i used) It said ni media ,and it was registered as XXXXXXXX U167CONTROL USB DEVICE can anyone help me with this.
Electronics -... | Answered on May 13, 2019
Topcon Gpt-8205a Robotic Reflectorless Total Station Logo
0 questions posted
Top Topcon Electronics - Others Experts
Marvin
Marvin
Are you a Topcon Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Topcon Electronics - Others
Most Popular Question
leica wild t1010 total station distomat
  • Electronics - Others
