Please follow the link My Bosch Nexxt 100 washer will not fill with water
SOURCE: Bosh error code E02
Hi. I had the same problem with my Bosch washing machine and called
Bosch...was told the same thing...$99.00 for service call. I managed to fix my
problem by doing the following:
The reason I did this was that I figured there must be some more waxy
buildup inside the machine in the cold lines and hoped the hot water would melt
it like when you rinse a greasy pan under hot water.
IT WORKED!!!
I hope this helps you.
SOURCE: Bosch Nexxt 100 series washer stops at 1st spin cycle
take a look at your manual that came with your machine go to problems usually at the back and see what that says,or go to the bosch website and type in your model number its on the inside of the door.i would suspect a program fault.adrian,,,,,
SOURCE: GE S3700E4WW DOES NOT FILL
It sounds like the complaint of the units board which is located beneath the unit. You may take it out from the unit, but it can be repaired only by a professional. Sometimes, it should be replaced which may seem costly.
SOURCE: My Bosch Nexxt 300 series won't spin
Possible that there is no output to the motor from the control panel in which case the control panel is faulty or if you can check the voltage on the motor at the time of program start , then it can be confirmed on the motor failure, motor capacitor failure.Also check the spindle for free run in which case it which case it can be jammed.
