Bosch Nexxt 100 Series WFMC1001UC Front Load Washer Logo
Question about Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
Bosch Nexxt 100 washer will not fill with water.
I select the wash cycle and press start. The start light turns solid red (like it is suppose to) The door locks (I can hear it and I even tried to open it). The washer will NOT fill with water (I checked the water lines and hoses, all fine). The machine will start to spin like it is washing then go to the finish and beep that it is done. Any suggestions?
Posted by Kathy James on
  • 1 more comment
  • Kathy James
    Kathy James Jan 25, 2014
    P.S. I already changed the carbon brushes. The washer will spin. THERE IS NO WATER!
  • Kathy James
    P.P.S. This machine does not have a screen to flash a code.
  • Kathy James
    FORGOT TO TELL YOU: I did clean out the filter too.
Stan Krzemien
    New Friend:
  • 12 Answers
Does the problem occur on both hot and cold washes. If not then check the inlet solenoid . If yes than check the board.
Posted on Jan 25, 2014
1 Related Answer
jimorris77
  • 411 Answers
SOURCE: i have a bosch nexxt 100 series washer during the
I am not a repair professional. I am a 78 year old man who has been making his own repairs for about 50 years. So the washer or dryer ID doesn't mean much to me. I came to fixya looking for a schematic for an really old AM/FM radio and just happened to see that more than 4,700 people were asking for help with a washer repair. I recently had a washer repair of my own and at that time I found an excellent video which showed me how to take my machine apart. This video made it possible for me to do my own repair. If you are repairing a dryer, a front load washer, or a dishwasher, I suggest you
go directly to www.applianceaid.com where they have very good step by step trouble shooting and repair information on both washers and dryers as well as many other appliances. If you have a direct drive top load washer and need help taking it apart this video is an early christmas present. I was so impressed with it that when I saw all these people needing help, I wanted to tell them about it. If you look at the back of your washer and the panel is solid (no small inspection plate to remove which would indicate you have a v-belt drive) chances are you have a direct drive and this video is just what you need. You can see it at www.acmehowto.com You will probably still need help in determining what the trouble is and how to fix it. After viewing the video or if you have a v-belt drive rather than a direct drive, I suggest you go to www.applianceaid.com where they have very good trouble shooting and repair nformation on most washers and dryers, dishwashers and many other household appliances. I think you'll find what you need there. Don't worry about the timer on a washer, they hardly ever go bad. I realize I haven't solved your problem for you, but I hope I have sent you to a place that will help you solve the problem. Good luck with it.
Posted on Dec 06, 2009
We have a Bosch Washing Machine nexxt 100 series wfmc1001uc, the water lines froze without us realizing, we started to washer while lines were frozen... in the end, we had to replace the hot water inlet as...
Bosch Washing Machine nexxt 100 This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Bosch Nexxt 100 series washer stops at 1st spin cycle
take a look at your manual that came with your machine go to problems usually at the back and see what that says,or go to the bosch website and type in your model number its on the inside of the door.i would suspect a program fault.adrian,,,,,
2helpful
3answers
Bosch Nexxt 500 Series Front Loading Washer
The only way is to disonnect the device from the controller board.
2answers
The timer works and fills with water. the belt is
So you start the easher it fills with water but does nothing else is that correct? If so It is possible that your door switch is faulty
Cycles take an exceedingly long time to complete
no, the problem is the the valve that stops water from draining is not working. or not shuting off all the way, water will try to fill but never does or does and leaks back out and try again. replace valve/pump, if you take it apart u will find your paperclip u left in u pocket
3helpful
2answers
Error code 02 on a newly installed Bosch Nexxt Washing machine
This is a trouble code for a fill that is taking to long. Make sure that both the hot and cold water valves are turned on. Hope this helps.
1helpful
3answers
Bosch Nexxt 100 series washer wfmc1001uc
According to the manual, you have to:
1. Turn program selector to "off"
2. Turn selector to Drain or Spin
3. Press the start / pause
Wait until program ends.
Open door.
or
Press "start / pause" until the start / pause light flashes.
1helpful
3answers
Bosch Nexxt 100 Series washer
Look into your manual, clean outlet filter & refit. Machine will not spin out if filter is clogged.
Top Bosch Washing Machines Experts
Marvin
Marvin
Steve
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
